Haltech S4 alternator back plug with haltech swap?
Old May 22, 2006 | 04:55 PM
hugo20's Avatar
The wire going from the back of the ALT to the ECU is gone with my old harness.
Is the backplug&WIRE needed for the alternator to work and charge the battery?
If it is needed, how do I wire it?
Old May 22, 2006 | 05:06 PM
RE TurboII's Avatar
Meow
isn't that plug hooked up to the lower engine harness (starter and battery harness). im not sure but i dont think its on the ECU engine harness. maybe someone will clarify it
Old May 23, 2006 | 05:46 AM
hugo20's Avatar
humm, yeah, but i think it was on the ecu harness.
Old May 23, 2006 | 02:29 PM
-=Lil Red=-'s Avatar
R.I.P. Guitarjunkie28
t2 harness it is on the battery harness.
NA harness its on the ecu harness.
Old May 23, 2006 | 04:12 PM
hugo20's Avatar
hummmm k your right. The problem is that my car was a S4 N/A.
What is the real use of the alternator back switch? Is it used to regulate or to turn ON the alternator or its only for the idiot light?
Old May 23, 2006 | 07:06 PM
eViLRotor's Avatar
Brother of the Rotary
One of the wires (B/W) is the voltage sense wire for the regulator, the other (W/B) is for the idiot light.
Old May 24, 2006 | 04:57 PM
hugo20's Avatar
ok, so how could I wire it to make it work with my e6x?
Old May 25, 2006 | 09:59 AM
nik's Avatar
nik
You'll need to wire the sense pin (Black/white wire) to a switched ignition source. You can use the same source as the haltech.
Old May 25, 2006 | 06:58 PM
hugo20's Avatar
easy shot! tnx
Joe428
16
Aug 19, 2015 06:24 PM
Machupicchu
Aug 17, 2015 08:27 PM
