Installing fuel system (Help)
Old May 21, 2006 | 12:07 PM
floman's Avatar
I just installed 1600cc secondaries along with a FPR in my fd. I have a Power FC in my car but it is untuned. When i turn the car on, it just hunts through the rpms a lot and breaks up when i slowly rev the engine. I was wondering what was causing this and how can i fix it. Also I need a place to mount my FPR so if anyone has any ideas please let me know. Thanks
-Cameron
Old May 21, 2006 | 12:49 PM
JDK's Avatar
JDK
Did you adjust the FPR?
Old May 21, 2006 | 01:09 PM
dhahlen's Avatar
FD Under Construction =P
I mounted mine on the front of the upper intake manifold.
You should check your fuel pressure.
And adding 1600cc injectors without a tune is just going to make your car run stupid rich.
Old May 21, 2006 | 03:53 PM
ALNY93R1's Avatar
Check for vacuum leaks.
Old May 21, 2006 | 10:05 PM
kuroi FD's Avatar
Did you change the injector size in the pfc? You can only go to 1300 i believe unless you have a datalogit not that this would effect your idle. I would definetly play around with your fuel pressure
Old May 22, 2006 | 02:46 AM
floman's Avatar
Thanks for the help guys. I will do what you suggested and hopefully it will work. Thanks again
-Floman
82streetracer
Aug 23, 2015 09:28 AM
