Haltech cant get road speed to work
Old May 18, 2006 | 08:38 PM
jacobcartmill's Avatar
just dont care.
i used this image that wankel7 posted and no matter what i enter for the roadspeed value, it shows zero.
http://img.photobucket.com/albums/v2...adspeedtap.jpg
i know my roadspeed works because my ABS light comes on at 5 mph.
is there anywhere else i can tap in for the roadspeed signal?
Old May 18, 2006 | 10:01 PM
RETed's Avatar
Cruise control?
-Ted
Old May 18, 2006 | 10:47 PM
Claudio RX-7's Avatar
EFI Tech Wannabe
I believe that the direct signal from the ABS sensor (even though it might be a magnetic reluctor) could also work, but if not, you can get an MSD magnetic signal stabilizer (MSD 8509, same that you could use for the reluctor addapters with the CAS) and run the signal through it, then to the Haltech.
Old May 22, 2006 | 09:55 PM
just dont care.
hey claudio, i looked through the entire ECU diagram and couldnt find an ABS sensor wire at the ecu.
Old May 23, 2006 | 01:23 AM
Wankel7's Avatar
Haven't we ALL heard this
Nah, that wire in question is straight off the instrument cluster because that is where the signal turns electric. It all starts in the cluster...
Man, I have NO idea why this is not working for you
James
Old May 23, 2006 | 02:04 PM
just dont care.
i am using the right haltech wire right? grey shielded with a yellow stripe?
Old May 26, 2006 | 12:26 PM
Wankel7's Avatar
Yeah, that is the wire I just double checked it....
Old May 26, 2006 | 04:33 PM
just dont care.
i got it to work. it was grounding out. all is well!
Old May 27, 2006 | 02:10 AM
Wankel7's Avatar
It is great ....when all is well
Th0m4s
Feb 26, 2019 02:04 AM
sherff
Feb 24, 2019 12:09 PM
Feffman
Racing Kills Lounge
Aug 15, 2015 06:19 AM
