FUEL PUMP SWAP 83 gsl
Old May 17, 2006 | 10:38 PM
Mr. Pink's Avatar
Not quite a new user
yeah can i take the fuel pump from an 82 gs and put it in 83 gsl? i know that i can and that the car runs. BUT i dont know if i have to swap regulators too. and if i have to swap regulators i dont know where they are anyways. so yeah input. NOW. PLUS what psi does the 82 run at. cause i can compare and know from that.
Old May 17, 2006 | 10:45 PM
trochoid's Avatar
Old Fart Young at Heart
Should be the same pump if they are both oem.
Old May 19, 2006 | 03:03 PM
Mr. Pink's Avatar
they arent though. the 82 pump is a diaphram, i think thats what theyre called, and the 83 has a impeller or whatever they are.
Old May 19, 2006 | 07:43 PM
trochoid's Avatar
With the idiotic prices of oem dealer parts, you can probably get by cheaper with a carter pump and a Holley 1-4 psi fpr.
Old May 19, 2006 | 07:51 PM
aussiesmg's Avatar
Thunder from downunder
This works well if you actually have the pump wired so it pumps and doesn't suck.....
Rotospectre
Mar 28, 2018 03:33 PM
