Attention!! AF61 TURBO OWNERS!!
Owners of the AF61 turbo. I have some questions. A couple of months ago I purchased the SS manifold off of Ebay (I know, I know) Now that I'm fitting it to the motor the manifold doesn't fir right!!! The wastegate flange rests on top of the crossmember and the turbo flange is to close to the side rail of the engine compartment. Am I the only one with this piece of SH*T problem??? I've come to realize that you get what you pay for. Can anyone recommend another maifold that would work with this the AF61 turbo that won't break the bank?
Thank any help would be greatly appriciated!!
Diego
Diego
Diego
Diego
FC mani http://cgi.ebay.com/ebaymotors/FC3S-...spagenameZWDVW
FD mani http://cgi.ebay.com/ebaymotors/Mazda...spagenameZWDVW
Both are bad designs (junk IMHO), but if your looking for something to connect your engine to your turbo at a really cheap price, these will suffice.
~Mike............
~Mike............
Trending Topics
Originally Posted by GUITARJUNKIE28
probably an issue with your motor mounts.
Af61R requires you to dent in the strut tower because the comp housing hits it. Also, There is a tab on the motor mount that the motor mount shield bolts to. You need to cut that tab off.
Actually guys it is not the FC manifold after seeing the pics that were posted. The problem I see is that the tubes for the wastegate aren't long enough. It appears to be about a 1/2" short, because the flange rest on top of the subframe. As for the strut tower, it has already been dented because of my last turbo and it still doeesn't fit. The turbo flange is to close to the rail, so I can't even sit the turbo properly on the manifold.
Originally Posted by andrewdruiz
Dont you have to cut into it? Remember when we rebuilt that one doods engine and he had that same turbo and a huge cut in his strut tower body.
kit wasn't very well designed...what can i say?
Originally Posted by RacerXtreme7
But the "kit" comes with the exact same POS eBay manifolds.
~Mike..............
~Mike..............
i love how everyone says pos, but nobody proves it. my friend has had one on his half-bridged, t66 powered fd for over a year with no problems, and he's even tracked the car a few times.
}). Ohh, not to mention the MANY MANY owners of those manifolds need to have the flange mating surface re-surfaced due to being warped strait out the box and many MANY having to egg-out the holes on at least one of the three flanges to get it to line up with its mating part.Now, as I said before...... if someone is just looking for a piece of metal to connect their turbo to their engine block at a cheap price, those manifolds work fine. Someone looking to make the best spool and power, those manifolds aren't designed for it. AND NO THERE NOT HKS COPIES. Ever see a GReedy or HKS stainless manifold???? They look nothing like the eBay ones. They also have proper taper and merge angles into the turbine.
There, enough of a rant for those POS manifolds from me. Its gotten off topic and I'm sure EVERYONE is tired of these useless debates. Lets try and keep this thread free from this crap. I'm sure it'll be hard for you NOT to respond and turn this thread to ****, so if you have something to direct at me send it via PM and keep this thread on topic.
~Mike..............
you're still under the impression that i'm defending the manifolds? the design is ripped off from the hks/greedy/ks stuff, but the runners are larger. it's not a $1500 manifold, so quit comparing it to a $1500 manifold.
I ran one of these manifolds for awhile...
The only problem I ran into was the warping of the mating surfaces like he had mentioned. I had mine resurfaced.
It is a cheapass manifold and works good if you're on a budjet.. my damn HKS manifold costs like $1000 for HKS or I can get one off ebay for $650 (still genuine HKS).
I agree, if you want a cheapass manifold to bolt on to your turbo... than thats the way to go. I also agree they do well for the price, and I also agree they are a **** poor design. Can't beat $150 though, lol.
If you're throwing in a $2000 turbo, you might as well throw on a manifold worth at least half that.
Just my $.02
Just my $.02
Justin at www.alienauto.com and also 1Revvin7 at www.turblown.net both make top quality manifolds that are still very affordable. All of the other shops I trust typically sell full kits and I'm not sure if they'd make a manifold for the 61R or not. But you really can't go wrong with either one of the first two shops I listed. Great guys with a great product and excellent customer service. Best of luck to you.
Zach
Zach
