It runs!
Old May 13, 2006 | 01:40 AM
PercentSevenC's Avatar
I need a new user title
It runs!
w00t!
https://www.rx7club.com/showthread.p...36#post5644936
Once I get it licensed, I'll be able to come to the Izzy's meets again!
Oh, and on that subject, it'll have to be emmissions tested, and I very much doubt that it will pass. What do you guys recommend, other than the usual "premium gas mixed with alcohol, run lean, etc.?" If I end up needing to get a waiver, how would you go about it? I'd appreciate any suggestions.
Old May 13, 2006 | 03:26 AM
KompressorLOgic's Avatar
I
thats good u got it running
first get it tested, if it does fail, to get a waiver you need to bring your failed sheet and have a certified emissions specialist/ shop to spend at least 150 tring to fix it. basicly find a certified shop and explain you only want them to spend that amount to try to make it pass, other wise they might try and charge u quite alot "tring" then they sign it saying they tried, then you run it again, if it fails still you apply for the waver in the office at the emissions station
Old May 13, 2006 | 02:30 PM
Upgrayedd's Avatar
Double Dose
Make sure the certified shop is one the the DOL's list, or else you can't get a waiver! I had my shop do some work after my failed emissions cuz I needed some maintenance and upgraded some parts. Spent about $850 and they wouldn't give me a waiver cuz it's not a "certified" shop... None of them are rotary specialists so I don't trust them with my car, even for $150!!
Old May 14, 2006 | 06:36 PM
Cgotto6's Avatar
If possible, ive always just registered the car in a county where they do not need to pass emmissions. So, if you have family in one of these locations, hit them up.
Old May 14, 2006 | 07:20 PM
rmriggin's Avatar
no clever remarks...
my community college is a certified tester. My old instructor is certified. Your car "technically" I think is excempt this year (maybe it is next). You may be able to pass if you installed like 2 high flow cats but even then it would be iffy. There is some stuff they sell at schucks that is supposed to guarantee you to pass if you follow the directions.
Old May 14, 2006 | 08:41 PM
Thanks for the replies, all.
Unfortunately, I don't have family in-state that lives in a non-emissions area. 'Twould be nice.
Anyone have any experience with Jerry's Little Car Shop in Kent? It's certified, it's fairly close by and I guess they specialize in Mazdas.
I saw the stuff at Schucks, but I was a little skeptical that it would work at all, much less in a rotary. Has anyone tried it?
Old May 19, 2006 | 08:56 PM
Upgrayedd's Avatar
Double Dose
Yes I've tried it just for kicks and it doesn't do anything if you don't have emissions components... It's just supposed to clean out your fuel system so there's no junk comin out... So I think if you had a COMPLETELY stock RX7 and you used it you would pass, but if you have NO emissions components whatsoever like my car, you're screwed!! As for taking your car to a mazda "specialist" there are pros and cons IMO.
They know the cars so you should feel comfortable (also bad cuz they know what emissions components there should be cuz one of the requirements is an inspection!). However, just because he's a mazda specialist doesn't mean he's a rotary specialist! I ran into that a bunch of that BS when I was lookin for someone to overhaul my gaskets and hoses. Plus, a lot of rotary specialists won't touch the FD because of the sequential turbos! T2's as well... They only do NA's... But, as long as they will work on your car and you trust them, go for it! I'm however, extremely paranoid and extremely picky so I trust NO ONE but people I know and reputable shops. Not saying anything bad about this shop though cuz I know nothing about it. To me location and order are KEY! If it's a bad area or the shop is all out of order or chaotic I wouldn't leave MY car there.... Just my 2 dollars! haha
Old May 20, 2006 | 09:08 PM
Yeah, I also have no emissions at all on my car, but I can reinstall some of it temporarily. Unfortunately, the rat's nest for the '84-'85 engine doesn't match up with the wiring harness for the '83 car, so I'm kinda SOL on that one.
I prefer to do the work myself where I can, but since I have to take it to a certified shop to get a waiver, I've got little choice. I'll probably end up taking it to Mazdas and More, as I'm more familliar with that place.
But who knows, maybe by some miracle I'll pass on the first try and won't have to worry about it.
Old May 20, 2006 | 09:34 PM
Upgrayedd's Avatar
Double Dose
HAHA yea that's askin for a miracle! My first time was a better test than the 2nd after I had some work done on the ignition system.... I'm still puzzled......
Old May 22, 2006 | 01:50 PM
quick_spoolin's Avatar
I'm Single..Turbo that is
Ok here is a tip for you guys..... When I was in college we played with the testing machines a bit… Basically we could take my turbo'd prelude with ZERO emissions and install a cat that has the side air tube then mount a stock air pump on the motor and basically route the pump so that the intake side had a little k/n filter on it and route the other to the cat to pump fresh air directly into your exhaust wink wink... passed every time.... but in theory I have never tried this on any rotary,... I graduated in 2002 so it’s been a while since I’ve been around any emissions testing tools....
Old May 23, 2006 | 11:29 PM
quicksilver_rx7's Avatar
Did your teachers not teach you how to punctuate in college?
Old May 24, 2006 | 11:35 AM
Well your mom was working on that, but after your sister wanted to join in too I couldn’t handle it anymore so I bounced. Also I just wanted to add. If you have nothing good to add to a tech thread shut the f@ck up...
Old May 24, 2006 | 01:17 PM
What's so technical about this thread? The fact that you learned how to put an airpump and a cataylitic converter on an engine and make the emissions cleaner? I hate to be the bearer of bad news, but automobile manufacturers have been applying this same technology for years.
Oh and just so you know, profanity and slander definitely showcase your level of intelligence.
Also, this isn't a tech thread. It's a regional thread, Einstein
Old May 24, 2006 | 04:17 PM
What the **** are you even doing in the area it says NW not SE so get the **** out... Don't be a bitch because you failed your emissions testing and didn’t think of that idea... make fun of my all you want its the ******* internet... want to make something of it say that **** to my face... After I knock you the **** out then will see who is laughing you little **** sucking bitch....
Old May 24, 2006 | 05:32 PM
z-beater's Avatar
REW'd FB
Quick, give it up he is not worth your time.
Percent, that is awesome. And this thread makes me very happy that I live in an emmision exempt county Look forward to seeing your and your pops again at Izzy's.
Old May 24, 2006 | 05:44 PM
notveryhappyjack's Avatar
1 bar boost
LOL your from the south....I wouldn't be making judgements about others grammer. Stereotypes are stereotypes casue they are usually true and the south is know for a few things other then their hospitality.
Ohh yeah, I took my 7 to carb/FI connection in kirkland and told them I only wanted to spend $150 to get the waiver and alex said that he would stop touching it after it hit $150, they are emmisions certified and are pretty good at cleaning up the emmissions.
Old May 25, 2006 | 11:27 AM
Sorry i was blessed with a healthy temper... prolly why i have those fellonies for all those fights lol hahhahah i guess for those that know me know what im talking about
Old May 25, 2006 | 07:31 PM
Sure thing, I will definately make it to the next one. Assuming, that is, I can get my electrical problems worked out before then (rat chewed on the wiring harness; no turn signals or backing lights at the moment).
Old May 26, 2006 | 11:35 AM
z-beater's Avatar
REW'd FB
HAHAHA, rat huh? That is funny...misfortunate...but still funny
Old May 28, 2006 | 10:26 PM
I wasn't making a sterotype ( I am starting to see a trend, though). My comment was not directed toward people that live in the N.W. It was directed toward one individual that made several lame posts in otherwise useful threads. This forum is supposed to be here as a resource for RX-7 owners & enthusiasts, not a sounding block for forum trolls.
C. Ludwig
Jan 30, 2019 06:31 AM
Rotospectre
Mar 28, 2018 03:33 PM
turbo-minivan
69
Feb 4, 2016 12:29 AM
The Shaolin
Sep 14, 2015 07:50 PM
