Rx-7 or not....That is the Question
Old Feb 14, 2002 | 04:36 PM
djmig28's Avatar
Newbie
Question Rx-7 or not....That is the Question
All of you Rx-7 heads out there, I need help. I have a 6 cylinder 3 series Bimmer. I have been doing work on the car and I just cant afford it, it is too expensive. Just because it is a bimmer the parts are 2x as much as the same part for a japanese or domestic part. I spend 2x as much $ on the car and get the same or less perforamnce increase.I am selling it and I am trying to decide if a 94 Rx-7 is for me. I Have heard excelent and bad things about the rotary. I have heard that after a lot of miles these engines will go, faster than others. I want to know more of the cons about this car. I already know the pro's, it is a badass car. I am just trying to figure out what kind of problems people mostly encounter in modifying these cars. I am only a novice when it comes to doing work myself , but I love racing. Please give my ignorant
self some much needed knowledge. Thanks again to anyone who can help.
Old Feb 14, 2002 | 04:38 PM
1FAST7's Avatar
the best thing to do is a search. this topic has been brought up many times. you will find all your answers on this forum. good luck
1FAST7
Old Feb 14, 2002 | 04:41 PM
FEDREX's Avatar
"Just Looking".......
From what I've gathered, the most common mistake is to turn up the boost without augmenting your fuel with either a stand-alone unit,(preferable) or an upgraded ECU. This typically leads to a lean condition which rotary engines have ZERO tolerance for, then you detonate and ruin apex seals.
