Hydrogen/Gas Rotary!!!
Old May 11, 2006 | 02:12 PM
Tenacious's Avatar
Dont know if this is a repost, but seemed pretty cool!
http://www.mazda.co.jp/motorshow/eng...tal/index.html
Old May 11, 2006 | 02:20 PM
SUPRAMAN
eh if it doesn't have a turbo it's not that exciting
Old May 11, 2006 | 02:21 PM
SayNoToPistons's Avatar
Insane Burning Diarrhea
why does this belong here?.... and repost x 364837249184729174123
Old May 11, 2006 | 09:06 PM
GUITARJUNKIE28's Avatar
multipersonality disorder
that's promising. not because of the hydrogen, but i've heard that hydrogen detonates very easily, so that would lead the way to lower compression renesis rotors...we may yet see 400whp on pump gas out of that engine in the future
Old May 11, 2006 | 09:50 PM
laundryhamperman's Avatar
just quickly, hydrogen can handle higher compression reatios's than the octane we use today....
Old May 11, 2006 | 10:12 PM
where'd you get that info? can i read about it somewhere?
Old Feb 3, 2009 | 10:31 AM
divbum's Avatar
Compression ratio
Could you supply more info on hydrogen's ability to be compressed more?
Old Feb 3, 2009 | 12:10 PM
Chaotic_FC's Avatar
I am also curious to know about hydrogen's resistance to detonation.
Old Mar 4, 2009 | 03:59 PM
speedturn's Avatar
The problem is the hydrogen supply. It is very light, so you have to have a lot of it to get the pounds of it you need to burn to make power. Either you store it as a compressed gas, and have a compressed gas cylinder at thousands of psi in your car, or you store it as liquid Hydrogen, and you must let the liquid boil off so the liquid tank doesn't explode. In 9 days your once full liquid Hydrogen tank will be empty just from sitting there. Hydrogen gas is dangerous, because you can't smell a leak, and if you have a leak and it burns, it has no visible flame for you to see. Several people have been burned from walking into a hydrogen fire they couldn't see. Several hydrogen facilities have blown up from leaks. I worked with hydrogen gas for several years as an aerospace research fuel.
Old Mar 4, 2009 | 06:32 PM
RacerXtreme7's Avatar
NASA geek
It takes a LOT I repeat a LOT of energy to get hydrogen. It takes MORE energy to extract it, then you get back out of it in return. Its a fuel source that is just to costly and not energy efficient enough to mass produce. That and the dangers as just mentioned.
~Mike..............
Old Mar 10, 2009 | 04:01 PM
I had another paper like this a few years ago but I can't find it.
This is another paper titles: The hydrogen-fueled internal combustion engine: a technical review
http://www.sciencedirect.com/science...a0d0f0e23265c8
Old Mar 18, 2009 | 06:15 PM
dtfd's Avatar
hydrogen fuel is a realistic possibilty but the trouble to prep fuel stations and the costs to produce the fuel and the cars is a little off-setting
Old Mar 19, 2009 | 01:26 AM
NASA geek
sooo... how does that make it realistic?
Old Jun 1, 2009 | 06:33 PM
bumper's Avatar
The RX-8 helped to open up the Norway Hydrogen Highway by participating in the Viking Rally recently.
Since I have too few posts to post the full link, here is what I can post
topnews.in/mazda-rx8-re-hydrogen-available-norway-2171614
There are a handful of H2 stations along the route in which to refuel.
datfast1
Old School and Other Rotary
18
Jun 20, 2019 10:53 PM
Under PSI
19
Sep 23, 2015 11:47 PM
datfast1
West RX-7 Forum
Sep 14, 2015 06:58 PM
andyvideopro
SE RX-7 Forum
Sep 5, 2015 06:56 PM
Murilli
Midwest RX-7 Forum
Sep 3, 2015 09:10 AM
