Power FC PFC Boost control Kit
Old May 7, 2006 | 06:18 AM
Richie1's Avatar
When I first bought my FD it was twin turbo and i bought a PFC + boost control Kit for the car, Unfortunatly before i fitted it the twins blew and i have now replaced them with a single, as the instructions are in jap for the FC i cant tell if you can use the kit for single, Also with the kit there was a new map sensor and a very short wire which plugs into the side of the FC Do i need to do this or can I replace the stock sensor with the new one I have tried this but the car revs to 3000 and then cuts out.
Any help appreciated as i will be getting it mapped up on RR next week.
Old May 7, 2006 | 01:17 PM
rynberg's Avatar
You have to adjust the PIM settings to account for the 3-bar MAP sensor.
Old May 9, 2006 | 02:49 PM
Richie1's Avatar
Thanks alot, I'm just trying to fix up all the small things before i take it to get rolling road setup. Also off the subject does anybody know where i can take a "tacho" reading from? I bought a HKS Injector controller and one of the wires needs a signal from it.
Old May 9, 2006 | 03:31 PM
rynberg's Avatar
Ack, what are you using the HKS injector controller for???
Old May 14, 2006 | 03:03 PM
Richie1's Avatar
I bought an engine from japan and it allready had 4 extra injectors welded into the manifold. I Read some good and some bad things about them but i am just going to use them as they are allready there.
Old May 14, 2006 | 05:54 PM
rynberg's Avatar
Screw that. Unless you're trying to run a T-88 at 30 psi or something, just get a different manifold.
Old May 15, 2006 | 02:18 PM
Richie1's Avatar
I'm running a greddy T78 hoping to run 15-16 psi
cristoDathird
28
May 30, 2019 08:47 PM
