Slot OEM rotors in SF bay area?
Old Feb 13, 2002 | 11:07 PM
jmseven's Avatar
Asset is Wealth
Do you know who can slot OEM rotors? I am looking for someone to do mine at a reasonable cost.
Does anyone know if the 88 T2 brake system (calipers, rotors, pads) will fit a 1990 non-ABS vert? I need to make sure before I start my project. I had purchased a whole new set at a very good deal.
Thanks!
Old Feb 13, 2002 | 11:26 PM
Scott 89t2's Avatar
SOLD THE RX-7!
do not do anything to the stock rotors. they will crack and brake on you. buy sloted ones. even bought drilled ones will crack. oem ones are fine for almost anything anyways. sloted/drilled rotors don't help braking.
Old Feb 13, 2002 | 11:27 PM
Scott 89t2's Avatar
SOLD THE RX-7!
and the brakes are the exact same for TII and vert.
Old Feb 14, 2002 | 08:46 AM
jmseven's Avatar
Asset is Wealth
Thanks....I have heard the opposite on slotting rotors. Have you, yourself tested this method?
Thanks for the confirmation on the fit.
Old Feb 14, 2002 | 02:16 PM
jmseven's Avatar
Asset is Wealth
TTT
Old Feb 14, 2002 | 02:20 PM
cymfc3s's Avatar
I Raise Chickens
i would never recommend someone slot or drill their oem brakes. New or used. Thats just not smart. Brakes is not something you want to screw around with.
Old Feb 14, 2002 | 03:38 PM
Icemark's Avatar
If you want to have slotted or cross drilled rotors, it must be done before the rotor has been hardened.
Doing after (as you are suggesting) is just asking for the rotor to shatter or develop cracks.
Old Feb 14, 2002 | 03:48 PM
jmseven's Avatar
Asset is Wealth
Thanks!...I guess I will leave them alone.
LMBTG
Sep 2, 2015 07:01 PM
VTECthis
Aug 24, 2015 09:01 PM
86glxNA
Aug 22, 2015 08:54 PM
