WHAT's The fastest time in a AUTO FD??
Old Feb 12, 2002 | 11:17 PM
sunnyxwala's Avatar
"I used to have one"
From: dallasDALLAS dallasDALLAS dallasDALLAS dallasDALLAS dallasDALLAS dallasDALLAS dallasDALLAS dallasDALLAS dallasDALLAS
donno, but i think it is way slower than the 5 speed
Old Feb 13, 2002 | 01:50 AM
unixpilot's Avatar
Check out my Mooseknuckle
Re: WHAT's The fastest time in a AUTO FD??
Originally posted by rx713bhell
I RAN IT AT THE ENNIS TRACK THIS WEEKEND and it sucked, i ran a really dissapointing time...what have u guys with auto's gotten??...what are your setups??
thanks
So what was your time? Dont worry I've got an auto too, I wont laugh..Did u shift with "hold"? How bout the launch?
Old Feb 13, 2002 | 09:21 AM
GsrSol's Avatar
Z06 powered FD
I don't know what the fastest time is but I think most people run anywhere from a 14.2-15.x stock. Not to long ago some guy was running a best of 14.8 with all the other runs in the 15's
Old Feb 13, 2002 | 02:44 PM
Automatic FD LOL
Old Feb 13, 2002 | 03:10 PM
RyanREX's Avatar
Killer Turbo Twins
Originally posted by jd93rx7
Automatic FD LOL
Shut your hole!
Old Feb 13, 2002 | 03:30 PM
TpCpLaYa's Avatar
T3DoW
yea it would be good to know what your time was so e can judge just how "bad" it was...there was also a thread a whle back where al the auto FD owners threw in some tips about launchin and good setups, try searching for it
Old Feb 14, 2002 | 06:16 PM
WANKEL POWER's Avatar
I had scans of a motor trend where they tested Auto sports cars......the best they got out of the sstock auto fd was....i believe a 14.2
Old Feb 14, 2002 | 09:15 PM
Brian_93's Avatar
T-88 FD
My FD was a Auto and I would always run horrible times, even with it heavly modded. The tranny just got not hold the power. So I ended up doing a manual swap, and its the best thing ive ever done to the car so far. By far worth it.
Old Feb 14, 2002 | 10:41 PM
JONSKI's Avatar
5yr member, joined 2001
https://www.rx7club.com/forum/showth...threadid=40146
Old Feb 15, 2002 | 11:03 PM
efiniracing's Avatar
My buddy here in Atlanta has a auto FD that did 11.9 W/ stock turbo's but w/ 120 shots of NOS.
Old Feb 16, 2002 | 08:24 AM
an_juan's Avatar
perhaps I may be of some help.....
my best time was 13.499 @ 107.xx in 90 degrees F & extremmely humid condition (Virginia). I have every conceivable bolt on mods and stock motor. The key is to powerbrake and just put it in D......I got my 60 ft time down to about 2.1....not bad for an auto. I lined up with a mustang cobra with straigt pipes and could not believe I spanked him (he ran low 14).
Note that I was running 15 psi and previously dynoed at 271 rwhp. This is where a huge problem. Apparently, the torque converter on FDs cannot transmit anymore than ~270 hp to the wheels. So even if the motor is cranking out 1000 hp, only 270 will EVER get to the rear wheels, the rest is transferred to heat and will destroy the torque converter and eventually the tranny itself.....which is why I swapped it out for a 5 speed.
Be careful
Old Feb 16, 2002 | 12:00 PM
nos?, didnt that blow the welds on the intake???, j/k thats impressive, what else does he have done to it??
He's pretty much got every bolt on possible. Race ported motor(stock apex seals, XS front mount(15lbs of boost), additional injectors, Nascar fuel pump, straight through pipes, his biggest problem is that he goes through torque convertors like it's spark plugs.
Old Feb 16, 2002 | 01:22 PM
bajaman's Avatar
Constant threat
sigh.......once again the question must be asked......WHY?
An automatic equipped FD is still a fast car, but NOT really what you want to take to the dragstrip! Hopefully you didn't buy the car thinking that it was going to be some sort of 'contender'?
With experience and proper shifting techniques you can get decent times, getting the launch down at the strip is difficult at best.
Buy an automatice equipped car for a lot of reasons, mentioned here in the various Forums quite often, but NOT for drag racing!
I mean hell, a stock MANUALLY equipped FD is only so-so for drag racing, in my opinion. Sure they will spank a lot of other stock cars, but....there are a lot of "spankers" out there too, just waiting to hand you your ***!
Old Feb 16, 2002 | 05:53 PM
RX794's Avatar
NYC's Loudest FD
Have your friend call Level 10, they have a torque convertor and tranny upgrade for the FD.
Old Feb 16, 2002 | 05:57 PM
Mr. Belvi's Avatar
You would get much better times out of your auto FD if you went to either 4.10 or 4.30 gearing.
Old Feb 16, 2002 | 11:24 PM
i was talking to Dave today at KDR about this situation cuz i also have a 94 Touring automatic. And he mentioned to me about the torque converter and 3500 stall converter to me also. This is the biggest problem leading to tranni failure. Also he said, and i quote "if you get those tranni upgrades from level 10 you will be spanking manuals and will chirp through first second and third, right off the line. I wonder of anyone has done this yet. I might look into this soon. Tihs might be the anwer to the auto guys' problems.
Old Feb 17, 2002 | 12:44 PM
Hhm, thats very interesting. I can't wait untill I tell him. Where can I get info about level 10? I've never heard of them.
Old Feb 17, 2002 | 12:54 PM
try www.levelten.com
they specialize in auto tranni's. There a bit expensive but their parts and work def makes up you spending all that money
Old Feb 17, 2002 | 01:56 PM
unixpilot's Avatar
I'd be careful about Level10. I am also looking for an upgrade to the Rx-7 auto, but I found a lot more negative comments than good ones about Level10. Not to mention their pricetag.... $3300 for there PTS "Bulletproof" Tranny??!?! Good lord, that could buy you a 5spd swap.
I could see maybe getting their upgraded Torque Converter for $500 and having an higher stall speed.
Also, they provide NO warranty, and if breaks you have to crate it up and send it back to them to fix it. Major PITA
Just search on www.supraforums.com and see how many bad stories you get about tranny's going out in less than a year and such.
Here's one of the most informative messages about Level10
From a guy at Sound Performance they do upgraded Supra Auto tranny's
This is Tim from SP. I had two "brand new" Level 10 transmissions completely broken down because I wanted to know what they put in there before I tried to run them. The guy who does the SP trans now did the work for me.
Level 10 puts USED parts in their transmissions. If they do replace the parts, they used non-OEM parts in two trans they sold to me. Over $3000 for used parts? Our trans guy said both trans would have blown inside of a week if I didn't have them taken apart, at my expense.
I had to have both of the Level 10's rebuilt, again at my expense. But, the expense on my behalf is only temporary. As soon as I start up my dyno business I'm going to inititate a class action lawsuit against Level 10.
By the time you can buy a trans from them, they hopefully won't be in business.
Old Apr 24, 2002 | 06:44 PM
moralesrx7's Avatar
i ran a 13.8 @95mph w/ intake and straight exhaust @ 12.5 psi i hit the boost cutoff 3 times during the second half wont risk it again intill i get the aem upgrade.
IB Cristina
West RX-7 Forum
Aug 20, 2015 05:46 PM
joel(PA)
Rotary Drag Racing
Aug 18, 2015 05:56 AM
GrossPolluter
Aug 16, 2015 09:50 AM
