single installed, running like crap
Old Apr 26, 2006 | 05:38 PM
willjs7's Avatar
3 and the hit for $100?
installed my single turbo. pulling 10 vac. idles at around 900-1000, very shaky, terrible throttle response. map is good, vaccume looks fine.
Old Apr 26, 2006 | 05:43 PM
willjs7's Avatar
forgot to mention an incosistant quick rev, without touching the throttle
Old Apr 26, 2006 | 06:29 PM
RX7WEEE's Avatar
Need a 20b FD.
Sounds like you may have a vacume leak. Does the idle bounce up and down alot? then settle out and run rough?
Old Apr 26, 2006 | 07:11 PM
Asleep's Avatar
7 Rx-7s since 1980
Guessing that since you are not mentioning AFR or wide band that you just assuming slapping a map on the car and assuming that it runs right?
Old Apr 26, 2006 | 08:18 PM
OWHAT's Avatar
check ur vaccum lines etc... when converting to single there is a heap of vaccum outlets of the throttle body that need to be blocked up
Old Apr 26, 2006 | 08:28 PM
dhahlen's Avatar
FD Under Construction =P
10 vac? thats low.. check your map sensor, and idle speed controller.
Mine did the same last night after i forgot to hook them up.
Worked fine.
Old Apr 26, 2006 | 10:44 PM
willjs7's Avatar
when i said the map is fine, i meant the map sensor is fine. the map on the PFC is the modded stock twins map. i havnt messed with the tuning just yet, i wanna get it to idle first.
Old Apr 26, 2006 | 10:58 PM
Asleep's Avatar
7 Rx-7s since 1980
Welcome to tuning. Get a wide band, search the forum here and the Datalogit forum and you have everything you need. The short-cut is doing it the right way.
Old Apr 27, 2006 | 12:22 AM
jamespond24's Avatar
I don't think tuning is an issue, it got to be a vacuum leak or something is not plug in right. This happen to me and it turns out to be the TPS, check the commander for the TPS.
Old Apr 27, 2006 | 06:43 AM
black beauty's Avatar
Worked fine.
I run about 10 vac or so...but i have a bridgeport
Old Apr 27, 2006 | 10:12 AM
Jason's Avatar
The one
What type of fuel system are you running?
Jason
Old Apr 28, 2006 | 07:16 AM
willjs7's Avatar
it has nothing to do with the tuning, the motor just isnt running right, somethings not hooked up.
Old Apr 28, 2006 | 07:17 AM
willjs7's Avatar
Jason
550/1600, walbro
Old Apr 29, 2006 | 08:27 PM
speedsilver7's Avatar
did you change the size of the injector in the pfc?maybe that is the problem
Old Apr 30, 2006 | 12:13 AM
willjs7's Avatar
did injectors a long time ago
PS. changed the plugs, runs like a champ.
Old Apr 30, 2006 | 12:22 AM
dhahlen's Avatar
dummy
Old Apr 30, 2006 | 12:07 PM
kuroi FD's Avatar
Ha ha nice.=, good to here. After i did my single install it was bucking and running like crap and I pull over and of course the map sensor is unplugged...
Old Apr 30, 2006 | 12:14 PM
dhahlen's Avatar
Speaking of being a dummy.. I did that the other day too.
I was trying to tune the idle.. and then i looked at my datalogit.. and it took me a good 2 minutes to notice the P row wasn't moving when i revved...
Stupid map sensor
sherff
Feb 24, 2019 12:09 PM
gabescanlon
Interior / Exterior / Audio
Aug 11, 2015 05:59 PM
