Engine Management Forum Use this area for discussing Haltech, Wolf 3D, Power FC, AEM and any other aftermarket ECU upgrades. Help/Questions/Tuning
engine managment beginner
Old Feb 12, 2002 | 02:51 PM
600HP CLUB's Avatar
i bought this book called "engine managment" to start out sure it tells me things i didn't know before but what the heck are the numbers represents in the maps?
-mike
Old Feb 12, 2002 | 04:40 PM
RX7SV's Avatar
Probably injector opening times in milliseconds, if it is a fuel map.
If it is an ignition map it would be the no of degs.
Old Feb 12, 2002 | 10:48 PM
600HP CLUB's Avatar
thanks, anyone else got any rule of thumb for me?
like x fuel should have x air or anything?
-mike
Old Feb 13, 2002 | 01:25 AM
Evil Aviator's Avatar
Rotorhead
There are usually two basic types of maps: fuel and ignition. The x and y coordinates are injector pulsewidth vs. rpm on the fuel map, and timing vs. rpm on the ignition map. In the better EMS systems, engine load is also included as a third dimension, z. Sometimes there are several x-y maps which the EMS "steps" through as the load changes, or on other EMS systems there is an additional z vector which makes up a 3-dimensional map. Any other settings are usually referred to as "trim", which basically means refinements which are not absolutely necessary to make the engine run, although they may be required for certain operating conditions.
If you are using Windows 95 or 98, you can play with the old Wolf3D 3.0 memory cartridge software.
http://www.wolfems.com.au/wolf_downloads.html
You can't tune an engine on paper, but basically you will get best economy at cruise somewhere around 14.7:1 AFR, while best power will be around 12:1 AFR for unleaded pump gas. BTW, the AFR is based on weight, not volume.
Rule of thumb - keep reading.
Old Feb 13, 2002 | 01:33 AM
600HP CLUB's Avatar
thanks alot, yep im reading still, looking for all the books i can find about tuning right now
-mike
82streetracer
Aug 23, 2015 09:28 AM
IB Cristina
West RX-7 Forum
Aug 20, 2015 05:46 PM
