Haltech Some 02 sensor and EGT sensor questions
Old Apr 23, 2006 | 03:44 PM
gonzz's Avatar
I'm doing a TII swap in a 1st gen. Custom making a 3" exhaust and have some questions on where to install my 02 sensor, LM-1 sensor and EGT sensor.. running a E6K and GT35R T04 on the eng.. any ideas? Also should I use a 02 sensor with my E6K or run a dedicated 02 for haltech and use my LM-1 sensor just for tuning? EGT sensor should be 1/2 way down the downpipe? Thanks for any info.
Old Apr 23, 2006 | 04:50 PM
Claudio RX-7's Avatar
EFI Tech Wannabe
The O2 sensor can go around 6-10" from the turbo on the down pipe, and the EGT should go closer, about halfway between there.
I would just use a 4 wire sensor as regular monitor for O2 ratios, and install an additional bung for the wideband and cap it, so you only use it for tuning, since the wideband sensor is more delicate than the regular one.
Old Apr 23, 2006 | 05:02 PM
gonzz's Avatar
Thanks for the help... Where can i get a nice 4 wire 02? local auto parts? Bosch universal?
Old Apr 23, 2006 | 08:26 PM
crispeed's Avatar
'Tuna'
You can also wire the wideband to the e6-k and with the right software datalog and monitor the A/F ratio in real time.
MoTeC
Sep 10, 2015 07:58 PM
FullFunctionEng
Full Function Engineering
Aug 25, 2015 08:17 PM
immanuel__7
Megasquirt Forum
Aug 22, 2015 09:34 PM
befarrer
Microtech
Aug 22, 2015 05:52 PM
