Check engine codes on 89-91
Old Feb 12, 2002 | 01:29 PM
tmak26b's Avatar
Hey guys, I got a question about checking engine codes on 89-91. After you stick the wires in there, are you suppose to start the car or just turn ON the car to check it? I started the car. 2 codes came on. After I removed the airflow meter plug and plug it back in, and after resetting the ECU. Both the codes were gone after I just switch the ignition to on. Judging from my observation, I dont seem to have any code because the check engine light goes out after about 3-4 sec with the wire in there. Normally when the wire isnt there, it stays on as long as the car stays in the ON position. AM I right or did i screw up somewhere and therefore not seeing hte code?
Old Feb 12, 2002 | 03:08 PM
Josepi's Avatar
Despise Enmity
You should never have your car running during this.
First turn car key till idiot light come on. Does your check engine light come on(normal)?
Mine goes out sometimes with the clock...
Now take the key out and pop the hood. Place a wire into the initial set plug (single connector, green near battery) and ground it (to the - of the battery is good). Keep it grounded.
Now get back into your car and turn the key forwards till the idiot lights come on. The engine light should come on as normal, then disappear, after that, if it has codes stored, if will display them.
Hope that helps.
Joe
Old Feb 12, 2002 | 03:11 PM
Scott 89t2's Avatar
SOLD THE RX-7!
of course the codes don't come back after reseting, that's the point of reseting them. go for a 30 min drive and see if them come back.
Old Feb 12, 2002 | 08:22 PM
tmak26b's Avatar
Tested the codes after an hour drive home. Everything is gone. I guess doing hte codes with the car running can cause funny things. Now I learned
Old Apr 5, 2002 | 05:48 PM
Prowla RX7's Avatar
It's Whatever
ok sorry to bring this from about a couple months ago, but the one thing im not sure of is, where would it display the codes? in the clock area? i havent had to do this before, so i want to know where to look before i do something stupid
Old Apr 5, 2002 | 07:28 PM
t_mak@mail.plymouth.edu's Avatar
www.1300cc.com has an article on how to do it
Old Apr 6, 2002 | 12:15 AM
Keith's Avatar
You probably never even had a code. When you start the engine with the wire jumpered, the ECU uses the check engine light to tell you whether or not the engine is running "closed loop".
Light off means too lean, light on means too rich, blinking light means successful closed loop.
Irv, Keith's dad
Old Apr 6, 2002 | 12:48 AM
Sniper_X's Avatar
irv, are you sure bout this?
I've never been in the car with the wire grounded and then engine running.
If this wire is grounded, then if the engine is running, the accessory and other idle altering components dont work.
its for setting timing and idle only.
thats my understanding.
befarrer
Microtech
Aug 22, 2015 05:52 PM
elfking
Aug 19, 2015 09:48 PM
ncds_fc
Aug 15, 2015 10:06 AM
