Sponsored by: CARiD
n/a '88 1.3 Qs
Old Apr 22, 2006 | 07:30 PM
KurtPB's Avatar
'91 Turbo Shadow
n/a '88 1.3 Qs
i dont really know a whole lot about rotaries, just the basic function and i found an '88 project. when i tried to crank it over(i had jumper cables to it), it tried, but just smoked out the tailpipe. the owner said that every spring, they would have to push/pull it to start. it has been sitting for 2 years. any idea how the seals on these were in '88? it has no visible rust what-so-ever and this is in Iowa. i was going to shoot an offer of $200 unless i feel that a rotary would be too much for me to work on/fix up or if the '88s werent too good. thanks.
Old Apr 22, 2006 | 10:09 PM
rxtasy3's Avatar
my question is, what color was the smoke? i don't know if it applys to all 2nd gens, but i heard that they were prone to leaky injectors in their old age. even if it needs an engine, it's worth $200.
Old Apr 23, 2006 | 03:36 PM
KurtPB's Avatar
'91 Turbo Shadow
blue-ish, looks a lot like the smoke that comes out of my turbo shadow. even if it is work $200, i'm definatly not ready for replacing an engine. any other ideas of what it may be? thanks.
Old May 2, 2006 | 12:28 PM
rusaccord's Avatar
I think that it breaks down like this: blue smoke means oil, white sweet smoke means coolant. I know that these engines should be burning through about a quart every 3k miles, but blue smoke seems to mean that it's burning a bit more than it should. In piston engines I think that means leaky o-rings. No idea what it could be in a rotary.
Old May 2, 2006 | 12:33 PM
Whizbang's Avatar
Respecognize!
blue aint oil. its gasoline.
i bet teh injectors are leaky as hell, and its stupidly flooded, which makes sense as to the each spring no start deal. search for the "unflood procedure" or look in the FAQ.
Old Jul 7, 2006 | 12:03 AM
Storme87's Avatar
Looking for a rx7
Take out the Egi Inj fuse under the hood try and crank it a bit then put the fuse back in.
datfast1
Old School and Other Rotary
18
Jun 20, 2019 10:53 PM
rxlevi7
Sep 26, 2015 07:28 AM
datfast1
West RX-7 Forum
Sep 14, 2015 06:58 PM
mulcryant
Sep 9, 2015 05:24 PM
