Power?? T88 34D greddy turbo
Old Apr 22, 2006 | 05:55 PM
philkeoghan's Avatar
Hi I just want to know if anybody runs one of these whats the power you are likely to get out of them and how much lag is there and other usefull info like power FC settings that suit this turbo
Cheers
Phil
Old Apr 22, 2006 | 11:00 PM
olyrx7's Avatar
My t-88 project will be finished very soon, this turbo will push some serious power!
At only 14psi were expecting close to 450whp, this turbo will blow 50psi so you will probably never use all the power that it will produce.
There will be lot's of lag with this turbo, there have been a few on this site that have had the t-88 so they could tell you. It's mainly a drag turbo!!
You need some major fuel upgrades to utilize the "real" power of this turbo.
I am running a Microtech, so I cant help you with all your questions.
Old Apr 23, 2006 | 12:08 AM
turbodrx7's Avatar
PURIST
Send ErnieT a pm, he will tell you all about the t-88 he had on his car before he went gt42R. He made 600+ on 30 psi i believe.
-Austin
Old Apr 23, 2006 | 12:00 PM
Gorilla RE's Avatar
GorillaRaceEngineering.co
-Austin
i think he had a SR Motorsports KKK stage 2! though they are close in size its still
a little diff. also as far as the power output......its more than enough! haha!
~Jonathan
Old Apr 23, 2006 | 01:23 PM
dhahlen's Avatar
FD Under Construction =P
http://dyno.zeroglabs.com/graph.php?...1&SUBMIT=GRAPH
Old Apr 24, 2006 | 02:42 PM
thanks guys, I am hoping to only run 14psi, looks like heaps of power
Old Apr 24, 2006 | 02:56 PM
turbodrx7's Avatar
PURIST
~Jonathan
That was on his red car that he had a few years back. Before he went gt42r on the cym he has now he had a t-88H.
-Austin
Old Apr 24, 2006 | 03:57 PM
snub disphenoid's Avatar
Isn't there a BIG difference between a Greddy T-88 and a Garrett T-88?
Old Apr 24, 2006 | 04:23 PM
darkphantom's Avatar
The king of the highway!
/\ yes big difference.
From what i heard from anthony the t88 isnt that laggy. theres 2 differences. THe T88 & the T88 34D. i was told by anthony that the Regular t88 isnt that laggy. that you couldnt tell the difference between the t88 & the T78.
My T78 boost around 4000rpms. & full boost by 5000rpms. i dont mind the lag (since my car is mainly a highway runner. but thats just my opinion!
its laggy but it can make big power gains. on a big street port expect 500 way before the 20psi mark!
Old Apr 24, 2006 | 04:51 PM
dhahlen's Avatar
I wouldn't say 500 WAY BEFORE the 20psi mark. It would be safe to say 20psi will get you low 500's. Perhaps 520hp if done tight... every setup is different.. and a GT42 has difficulty making those claims.
You'd be close to it by 20
Old Apr 24, 2006 | 05:09 PM
i didnt mean way before as in 14-13psi. just before 20psi. but ive rode in a base t88 and a little difference from my t78. about 2000rpm difference in spool
Old Apr 24, 2006 | 08:47 PM
Gorilla RE's Avatar
-Austin
oh i see! cool thanks man!
~Jonathan
Old Apr 24, 2006 | 11:53 PM
Just to give you an update of what my setup is and any one can recomend what they like,
I have a rebuilt full bridge port power fc profec b use to run a td06 25g with 375hp at wheels 4 850cc walbro big front mount
What do you recon??
Old Apr 25, 2006 | 12:21 AM
I just finished my T-88 car... Unfortunatly I accidently left a 30 psi wastegate spring in the car for the dyno. But it made 417 rwhp at 20 psi at 70% throttle. Im very happy with the spool time of the 88-34d we were seeing 2 psi around 4200rpm and 20 around 4600 rpm. My motor has a large port though.
Old Apr 25, 2006 | 07:39 AM
dhahlen's Avatar
That wastegate spring is going to make it laggy.
Throw a 10psi spring in there and use a boost controller to set your boost, makes a big difference.
Old Apr 25, 2006 | 07:57 AM
RX794's Avatar
NYC's Loudest FD
I'll post a preliminary 450RWHP dyno pass that I made previously with a T88 34D on Mobil 93 octane pump gas, and stock Mazda 9 platinum plugs all around. My goal was to see how far I can take the car under the gasoline and sparkplug conditions described. For this dyno pass I richened up the fuel on the secondary injector lag time on the PFC by .06 more than how it is set when normally tuned. My reasons for doing so were because I wanted to be safe, it ended up being a little too safe and causing the car to have too much fuel on top, and loosing power(henceforth the sloppy graph on the top of the powerband). It seems that I probably lost about 20-25 peakHP or so because of this on this pass. My timing was pretty conservative and could be bumped up a degree or two, and the boost could be raised as well. The sparkplugs that were on this run have been in my car for about a year or so, put a lot of mileage on the car and I'm still using them, I'm pretty impressed by them for now(Go Mazda and NGK!), even though I will probably be changing them the next time I go tuning just to keep things fresh. This was on a Dynojet, and the horsepower rating shown is true, it's in SAE correction(I don't use anything else because I've seen some dyno graphs posted on this forum before that were not in SAE correction, and therefore misleading, SAE is the way that the Society of Automotive Engineers measure HP, and what the industry consider to be the standard. I could've posted a standard correction factor and shown bigger HP #'s, but that's not realistic and I'd by lying to myself as well as everyone else). Also I don't use any smoothing on the graphs, I do this because the graph will show every little abnormality and that helps when fine tuning(That's why just by looking at this graph you can tell the car was too rich up top). I was also having problems with the ignition signal pickup to the dyno on this pass and therefore couldn't get an rpm signal, therefore not being able to get a torque reading, sorry about that. I will return to the dyno after me and JD(Boostn7) can meet up sometime soon and do some more tweaking with the tune.
Old Apr 25, 2006 | 10:21 AM
REALLY!!!! Never thought of that... I just enjoy large amounts of throttle controlled boost.
Old Apr 26, 2006 | 12:30 AM
GreenMean937's Avatar
its a rx7 not a miata!!!
what spring comes in the wastegate with the t88??? and how much does the 10 psi spring cost if not already equiped in the greddy type c wastegate?
Old Apr 26, 2006 | 01:49 AM
iceman4357's Avatar
I hope my T78 will hit full boost by 4k rpm with my new halfbridge
Old Apr 26, 2006 | 05:19 PM
zayrx7's Avatar
the mazda zoom zoom store
Eric! I'm seeing full boost 16lbs @4000 rpm, the 1/2 bridge really make the t78 more fun
Old Apr 26, 2006 | 06:10 PM
Will I be able to expect the same form the T88 34D 18cm???Anyone have any good power FC maps for this setup??
Old Apr 26, 2006 | 06:17 PM
dhahlen's Avatar
Your mom enjoys large amounts of throttle controlled boost.
DOH!
Eh... the 'Yo Mama' show is addicting.
Old Apr 26, 2006 | 06:18 PM
dhahlen's Avatar
You want to use someone elses map???
Big mistake...
If you're going to do it, have it tuned by a reputable tuner otherwise you're throwing all that stuff into your engine and just asking to blow it and throw a seal through the turbo.
Old Apr 26, 2006 | 09:08 PM
Nah I was really just interested. just for a comparison, don't want to go to all this trouble then blow it up
Old May 1, 2006 | 07:36 PM
Anyone else got any more info on what a t88 34d 18cm.
POWER from these on a 13b I'll be interested in and your setups thanks.
I'll try and get some photos and maybe a vid of mine running
