Spark Plug Decesion. Did a search.. 500hp+
Old Apr 22, 2006 | 01:25 AM
dhahlen's Avatar
FD Under Construction =P
Well I see a topic on just about every type of plug, but nothing is giving me the answer i am looking for.
I currently run NGK 9's all around, these are good for 420hp. I am moving up to 550hp range and I am going to need colder plugs.
I have a set of 10.5 and 11 HKS plugs.. but I plan on using these for the track only.
Needed:
-Plug that will handle 550hp range
-Plug that will work as a daily driving plug (meaning it can start cold, and idle fine until car reaches optimal temperature)
-Can't run more than $10 a peice.
Most race plugs are $25 and up. I just need a set of plugs that can do it.
Now.. I hear stories about gapped vs resistor type plugs.. etc etc. The stockers are resistor type with the electrode in the middle correct?
I am looking into the following:
NGK BR10EIX (10 heat Range, Iridium)
or
NGK B10EGV (10 heat Range, Gappable, non resistor type)
I also hear the B10EGV requires a thinner socket for installation.
Basically, from EXPERIENCE which plug would be best suited?
I'd be running 22psi with pump and methanol, daily driver. See sig for additional mods. THanks
-Darren-
Old Apr 22, 2006 | 03:52 AM
KeloidJonesJr.'s Avatar
strictly business
What about a ignitionamplifier? Like the HKS earth kit? http://hksusa.com/categories/?id=1954
Old Apr 22, 2006 | 08:33 AM
Bacon's Avatar
IRS 4 Life
The Egv's are your best bet. sparkplugs.com carrys B11egv's also which I run and have 0 problems with. I believe crispeed and a few other real high hp guys swear by the EGV's also
www.kgparts.com carries the socket you need for like 20$
Old Apr 22, 2006 | 11:45 AM
dhahlen's Avatar
Check out the sig boss. I run a twin power =)
Old Apr 22, 2006 | 11:47 AM
dhahlen's Avatar
Will B11EGV's give me a problem on cold starts? I assume the ignition amp will help with that... and what is the gap I need to use on them?
Old Apr 22, 2006 | 01:32 PM
1wide7's Avatar
i run the 10egv with no problems andi got them at auto zone
Old Apr 22, 2006 | 01:47 PM
dhahlen's Avatar
What kind of power are you putting down?
I'm concerned with them fouling under daily driving conditions.
I am thinking of the NGK Racing R6725 11 heat range. I hear they work alright for daily driving.
I should be putting down 500+ hp.. on a T51r KAI at 22psi with Pump and Methanol.
Trying to find the best way to go.
Old Apr 22, 2006 | 02:58 PM
strictly business
Sorry
Old Apr 22, 2006 | 03:13 PM
twokrx7's Avatar
Need more sleep
R6725 10.5 heat range ran great for me on the street, with a good tune and a lean idle and cruise you should have no problems with fouling. These performed way better, and I mean way better than any other plug I tried. Cost >> $10 tho
Old Apr 22, 2006 | 04:29 PM
Bacon's Avatar
IRS 4 Life
To be honest i havent had any prob,
but im running 2 crane HI-6 boxes, and using the lx92 fireball coils. so my ignition could get them to fire in pretty much anything.
Daily driving= still get to go to WOT quite often , with a good tune you'll be fine
Old Apr 22, 2006 | 05:33 PM
dhahlen's Avatar
Cheapest I'm finding them for is $25 a peice... can you show me where you got them for $10??
Or did you simple mean COST > $10 - cause they're not cheap. I got HKS plugs, but i refuse to use those.. lol. They're too damn expensive as it is.. i guess they're about the same.
If I use R6725 11's in the Leading and BUR9EQP or whatever in the trailings.. would that be ok?
Old Apr 22, 2006 | 06:47 PM
dhahlen's Avatar
Anyone? gotta order these by Monday and have them ready for the tune.
Old Apr 22, 2006 | 08:15 PM
pistonsuk's Avatar
Doesn't look like your going to beat the B11EGV's....$5.37/ea.
http://sparkplugs.com/results_cross....11EGV&x=46&y=5
Have people found these to foul when street driven?
Justin
Old Apr 23, 2006 | 08:01 AM
FD Rey's Avatar
I brake boost
what are you supposed to gap the B11EGV's?
Old Apr 23, 2006 | 09:46 AM
dhahlen's Avatar
I hear people gap them at .022
Old Apr 23, 2006 | 05:41 PM
dhahlen's Avatar
ANybody?
Old Apr 23, 2006 | 06:42 PM
dhahlen's Avatar
Oh well...
2 - NGK Gold palladium
Stock Number: 5831
Part Number: B11EGV
Unit Price: $5.37
Extended Price: $10.74
Stock Number: 5927
Part Number: B10EGV
Unit Price: $5.37
Picked up a set of 10's and a set of 11's
We'll see which one works best, starting with 10's. I'm going to gap them at .022.
I am going to run the standard BUR9EQP's for trailing.
Old Apr 23, 2006 | 07:08 PM
pistonsuk's Avatar
How will you know if they are too hot? Detonation?
Keep us posted.
Justin
Old Apr 23, 2006 | 07:16 PM
dhahlen's Avatar
No..
Kan is tuning.. if I am getting misfiring, they're not cold enough. I wouldn't expect to see misfiring until 18 psi plus... IF they weren't up to par. The 10's should be fine for 23psi. Someone told me the rule of thumb was 1 heat range per 5psi over 15. So if I am going to do 20psi, 10's should be fine... 23psi would be about 10.5 but i am using methanol... and Steve knows what he is doing. I am not sure how accurate that little 'rule' is.. but we'll see.
I have race plugs from HKS on hand just incase i need to swap those during the tune.
Old Apr 23, 2006 | 08:05 PM
1wide7's Avatar
i made 463@18 on vp103 with the 10s and no issues
Old Apr 23, 2006 | 08:19 PM
dhahlen's Avatar
ignition setup?
Old Apr 24, 2006 | 10:23 AM
1wide7's Avatar
hks twin power amp. the power should have been higher but i was still on the stock cat so there was an exhaust restriction
Old Apr 24, 2006 | 05:12 PM
darkphantom's Avatar
The king of the highway!
i just bought 2 10's from racingbeat for 9 bucks a piece. i plan running 2 9's & 2 10's
http://www.racingbeat.com/resultset....rtNumber=11524
Old Apr 24, 2006 | 05:15 PM
dhahlen's Avatar
You got ripped off...
https://www.sparkplugs.com/results_c...R10EIX&x=0&y=0
They have them for $6.95.
Anyway, the EIX looks good.. but we'll see how the EGV's work and if all else.. i'll throw in my HKS plugs and spend $120 for a new set each month.
Old Apr 24, 2006 | 05:39 PM
GoRacer's Avatar
Speed Mach Go Go Go
That depends if he's local. I can drive to Racing Beat and pick them up the same day. It's not very far either. Sparkplugs.com is in CA so in addition to tax there is a shipping fee.
