sunroof deciedt to stop working in open position
Old Feb 11, 2002 | 12:30 PM
Powridah's Avatar
K It just stopped working ! luckily i had a allan key to close it. i thought it was maybe the motor. but i talked to someone and they said it was maybe the tracks jammed up. so i spent 7 hours being careful not to break anything taking it all out. i got the whoel assembly out. i cut the two wires that go to the little motor and hooked em up to a battery charger and it works fine. (when i had the assembly out it moved the sunroof bak and forth). I really dont know what the hell is going on. I cleaned my tracks out. Can the sunroof peice itself be taken off from the track ? cuz i couldnt figure out how. im gettin really frustrated guys. Ive gotten to the point that i just want to start beating the **** out of my car. cuz everything is going wrong.
Old Feb 11, 2002 | 12:33 PM
Powridah's Avatar
oyea btw the fuse is fine. i checked it several times. all the wires are connected to the buttons and the relay
Old Feb 11, 2002 | 01:02 PM
Audiofight's Avatar
Your switch may be shot.
My sunroof still doesn't work, but I haven't torn it apart to try and fix it yet. I know it isn't the switch or fuse. Four of the wires coming off the sunroof are cut, and other ends of those wires are gone.
Where are you located? I may have an extra switch to sell ya, for like $5-10 shipped. I gotta figure out how to test it, but once I do that and prove to myself that both switches are fully functional, I can get rid of the extra.
Help me figure out my problems and I may be able to solve yours cheap as well.
streetlegal?
Mar 17, 2022 02:46 PM
highspeedrider
Sep 8, 2015 07:55 PM
andyvideopro
Aug 20, 2015 10:55 AM
