Sponsored by: CARiD
block off kit on stock turbo's
Old Apr 11, 2006 | 10:22 PM
fastyoungone's Avatar
rx7 fanatic
I was lookin on rotary performance at their block off kit. I've got a 1993 automatic, with a ported engine and some simple other upgrades. I know that these are generally used for single turbo upgrades, (I'm still running stock twins) but I can still use some of the block off pieces can't I? And if I can, is it worth it? which ones? thanks.
Old Apr 12, 2006 | 09:00 AM
zullo's Avatar
Obsessed
Certainly you can. The plates are primarily for emissions accessory removal and have little to do with the turbo(s) you're running. I just installed a full set on my engine with stock twins.
Worth it? What are you trying to accomplish? You won't pass emissions but you will tidy up your engine a bit. If you still have a cat and an air pump, you don't need most of the plates.
Old Apr 12, 2006 | 11:50 PM
rx7 fanatic
i guess i was asking if the money was worth the mess of hoses it takes out. here's another question, I'm probably gonna buy another one completely stock. could i still install it on that? by the way, you ever in tulsa?
Old Apr 21, 2006 | 10:49 AM
zullo's Avatar
Obsessed
usually the removal of the cat and/or air pump creates the need for block off plates. If you're going to be pulling the uim anyway and don't worry about emissions or resale, sure...
I try to make it to Hallett a couple times a year, so yes.
Old Apr 21, 2006 | 05:30 PM
crabcakesyum's Avatar
yea it is worth the money i think personally
Old Apr 21, 2006 | 07:07 PM
rx7 fanatic
thanks guys.
cristoDathird
28
May 30, 2019 08:47 PM
