help!!!!
Old Feb 11, 2002 | 01:35 AM
chubbrx7's Avatar
help!!!!
after weeks of trying to get my 86 rx7 to start i finally got it started, but their is three questions that i still have (1)during the weeks of cranking my engine the starter went out, so i had my friend push me with his car to get my 7 started, when i put my starter in will it start like it is suppose to or will i have to push it all the time.(2) my oil pressure is very low , it never goes above 30 on the guageand there is plenty of oil in there, dont see any leaks(3) When i rev the engine from outside the car i hear a pinging sound coming from the passenger side, sounds like its coming from inside the exhaust manifold or the passenger side of the engine.
by the way i have done all the things like the atf trick,help!
thanx for all you guys help
Old Feb 11, 2002 | 01:57 AM
flying taco's Avatar
Rock Star.... almost
If u put a new starter in you won't need to push start your car... check your oil pressure sensor... and i really have no idea about the pinging.
Aaron
Old Feb 11, 2002 | 02:42 AM
chubbrx7's Avatar
the only reason that i had to push start it was because it would not start by cranking it(the car had been sittin for a while and would not start even after the atf and new plugs)
Old Feb 12, 2002 | 02:56 AM
chubbrx7's Avatar
can some one help plz!!!
Old Feb 14, 2002 | 06:17 AM
chubbrx7's Avatar
can anyone help me with these problems, i want to drive this car
Old Feb 14, 2002 | 06:31 AM
The Ace's Avatar
Greek Power
1) New starter -> you dont have to push-start the car
2) Oil pressure: if there is enough oil (i.e dipstick to the max), then check the pump (take off -very fast - an oil line to see if oil circulates. The pressure rises only when you are on the pedal, not at idle
3) Pinging sound ? no clue whatsoever. Maybe something got unscrewed ? Or loose ?
Old Feb 14, 2002 | 08:26 AM
J-Rat's Avatar
Alcohol Fueled!
Hey
Chubbrx, have you checked your PMs? And do you have AIM more MSM? I put my number in your PM box...If you want to call, I can hopefully help you.
Rat
Old Feb 14, 2002 | 11:57 PM
chubbrx7's Avatar
thanx for the response, what does AIM and MSM mean???
Old Feb 15, 2002 | 08:23 AM
J-Rat's Avatar
Alcohol Fueled!
AIM is Aol Instant Messenger. MSM is Microsoft messenger. Sometimes its easier to chat in order to help you with your problem.
Old Feb 15, 2002 | 12:12 PM
chubbrx7's Avatar
no i dont think i have either of those i use quest as my internet provider- anyways i have your # and i am going to call you but i have to get a calling card since it is long distance for me-i am going to find a starter today , if my car starts by pushing it should it start when i put my new starter in
