Power FC "global" injection trim on PFC ?
Old Apr 10, 2006 | 02:08 PM
BicuspiD's Avatar
Infamous...Butcher...
Is there any way to bump the entire map up a little for fuel everywhere? I don't want to mess with the individual points, or the curve.. just simply put a slight gain on the injection to richen it up everywhere. IF I had an adjustable regulator I'd just bump it up a poundor so... any tips?
Old Apr 10, 2006 | 02:12 PM
FastHatch's Avatar
You can either adjust the "Injection vs. RPM" settings or the injector settings.
You can change both settings with the Commander, "PIM Volt" > Next > "Engine RPM Specific Correction" or "Injector" and then change the Injector Pulse Correction.
Old Apr 10, 2006 | 03:26 PM
cewrx7r1's Avatar
Eye In The Sky
The manual explains this.
Old Apr 11, 2006 | 01:46 PM
BicuspiD's Avatar
thanks, I didnt think about the engine rpm specific correction tables. This should work until I get it on a dyno to retune
Einheri
Oct 7, 2015 12:23 PM
spokanerxdude
Megasquirt Forum
Oct 6, 2015 12:28 PM
baix2
Power FC Forum
Sep 28, 2015 09:40 AM
