turbo timer and alarm
Old Feb 10, 2002 | 10:11 PM
suprfast's Avatar
okay i included this in one of my old topics but didnt get much info. i now know what alarm and turbo timer i want but dont know if they can go together or if anyone can install it. here is the gear.
HKS type 1 turbo timer and viper ES600 alarm. i want both of these but the guy at circuit city didnt know how to install. he wasnt the installer just a sales man. i may also check out good guys. let me know guys. i really need an alarm and turbo timer.
kris
93 touring(red)
Old Feb 11, 2002 | 01:22 AM
DK's Avatar
DK
40k worth of fail
Do you know that some alarms have a "turbo timer" included in them? They'll leave the motor running for a set period of time after you turn the ignition off, which is usually done by tapping and/or holding the brake pedal before turning the car off.
I don't know if that alarm is compatible with a separate turbo timer, though ... sorry. Just trying to help you see what's out there.
Old Feb 11, 2002 | 01:52 PM
suprfast's Avatar
any body else with info regarding this topic. i really need to know. email both HKS and DEI about this topic and am awaitng to see what they have to say.
kris
Old Feb 11, 2002 | 05:00 PM
the_saint's Avatar
how long do you run your turbo timer?
Just get your alarm to automatically self arm after 1 minute (or whatever you can set it for).
I get my car to arm the alarm after 30 seconds after the turbo timer has shut off.
just remember that your car will be armed when you go to get into it.
the_saint
Old Feb 11, 2002 | 05:56 PM
unvmyrx7's Avatar
i installed my greddy turbo timer and viper 800esp alarm myself, u do not connect the ignition trigger(yellow wire) on the starter disable relay to the alarm
Old Feb 11, 2002 | 06:37 PM
martini's Avatar
All I know is that my alarm works perfectly with my turbo timer.
but I have a remote start system installed too. they go hand in hand.
First off, I have to make sure my feet aren't on any pedals, I have to make sure the ebrake is pulled, and the car is out of gear. Then I hit a button on my remote BEFORE I take the key out. At this time, I take the key out, and the car stays on. This is not using the turbo timer yet.
If I hit any buttons (windows, sunroof, brake, clutch, gas, whatever), the alarm part will shut the car off, and it will go into turbo time mode.. But you don't want it to do that, so you get out of the car, close the door, and hit the alarm engage button. You'll hear a couple chirps, and the car will then lock up, and the alarm will be armed. The car is now in turbo timer mode. It's still running. After the turbo timer is finished, it will chirp a few more times, and your alarm will still be armed.
When you get back, you can either hit the button on your remote that will start the car (and then disarm the car), or just hit the disarm button, hop in, and start it with the key.
It's now a habit to always push that button before taking my key out. It isn't really a nuisance at all. I love it because with the turbo timer, I never have to worry if I might've left the car in gear before using my remote start.
Old Feb 11, 2002 | 07:31 PM
GoRacer's Avatar
Speed Mach Go Go Go
Exclamation you don't need a turbo timer
If you have a stock alarm, keep it. Otherwise the door silinoid thing gets burned out with aftermarket ones. Spend your money on a LoJack theft recovery system instead.
You don't need a turbo timer. Just don't hit 10+lbs of boost in the parking lot, zip in a space and shut the engine off. You need to either putt the last minute or two or take your time parking with the engine idling.
If you still insist on getting one then get either the Apexi or Blitz. Both have a model that determines how long before shutting off the engine by how hard you've hit boost. Plus the Apexi model hooks up to the parking brake and kills the engine if it is released (not sure if Blitz can do that or any other can be modified to do that).
I have an HKS and I only use it to warm up my car at night (so I can take the key out), otherwise I don't use it all...except to impress the young girls (lol).
Old Feb 11, 2002 | 07:36 PM
Foz'sRX-7's Avatar
Greddy works the same way. It is wired to the emergency brake so you can't engage it without pulling the brake. Also, it will compute the required idle time based upon your RPMs.
cristoDathird
28
May 30, 2019 08:47 PM
pzr2
Aug 15, 2015 08:29 PM
