Symptoms of a bad tranny/diff mounts?
Old Apr 7, 2006 | 06:31 PM
DASUPACAT1's Avatar
Well lately every time I shift I hear a metallic thump/clunk from under the car. This happens when I let off the clutch after the car has been put into the gear I select. Is there any way to tell by doing a visual inspection? What should I look for? Are the mounts hard to replace? I'm doing an engine oil/diff oil change tomorrow so I'll be under the car to look.
Old Apr 7, 2006 | 09:43 PM
DASUPACAT1's Avatar
Anyone?
Old Apr 8, 2006 | 01:21 AM
Black91n/a's Avatar
Is it while you're letting the clutch out that you hear the noise, or after, once you start accelerating again? Is there some jerkyness associated with the noize? If it's after the clutch is engaged and when you get back on the gas it's probably a diff mount. If it's from the rear then definetely check the front diff mount, as it's known to break and cause a metallic clunking sound. Other than that it could be an engine or transmission mount, but that's unlikely.
Old Apr 8, 2006 | 05:06 AM
DASUPACAT1's Avatar
A little of both. There is some jerkiness too.
Old Apr 8, 2006 | 10:12 AM
Syncro's Avatar
Buildup Thread Encourager
Check the u-joints on the driveshaft, too.
Old Apr 8, 2006 | 10:15 AM
73828793's Avatar
went RX crazy............
clunking during gear changes like reverse etc... is diff mount. usually when the trans mount starts going bad you will get vibrations inside the car when you rev the engine, even in neutral.
Old Apr 8, 2006 | 11:45 AM
rxspeed87's Avatar
clunk. clunk jerk jerk
sounds like a diff mount to me. I have the same problem
real easy to figure out go under the car and reach up to the front snout of the differential and push up. watch if move up fairly easily.
problem is it shouldn't
Old Apr 8, 2006 | 12:29 PM
DASUPACAT1's Avatar
well it seems after i shift into and out of a gear like 1st to 2nd then into 3rd as soon as I let off the clutch and get on the gas is when the clunk happens.
Old Jun 20, 2006 | 04:18 PM
-Ryan-'s Avatar
have you fixed your issue...
I have the same issues and have pinpointed the front diff. mount..
I have a thread on it today...
I would like to find a write up on how to replace it... what have you done?
Old Jun 20, 2006 | 04:58 PM
socalrotor's Avatar
There is a sticky on the FAQ if I recall correctly!
EDIT*****
https://www.rx7club.com/2nd-gen-archive-72/easy-way-change-diff-mount-39026/
Old Jun 20, 2006 | 05:08 PM
-Ryan-'s Avatar
Thanks man.. you always pull through..
Could you look at my thread that I started today to see pics of my situation and verify its a broken front diff mount
https://www.rx7club.com/showthread.p...9&page=1&pp=15
MazdaAspec
Sep 9, 2015 02:04 PM
86glxNA
Aug 22, 2015 08:54 PM
Wolf_
Aug 11, 2015 04:23 PM
