Please not an apex seal
Old Feb 10, 2002 | 07:36 PM
877's Avatar
877
Question Please not an apex seal
Hey everyone!
Recent tune up and other parts but now I have an idling problem. The L1 and T1 plugs are clean and the other two are blackened. Is this timing? TPS is fine, new wires, etc....??????
Old Feb 10, 2002 | 07:51 PM
Brian_TII's Avatar
Re: Please not an apex seal
Originally posted by 877
Hey everyone!
How is the power? How does the motor sound? Please give a lot more detail.... otherwise everyone will just be guessing. Also have you pulled a plug on each rotor and listened for compression?
Old Feb 10, 2002 | 07:59 PM
877's Avatar
877
Compression seems fine. She sounds like she is running underwater. No power?!
Old Feb 10, 2002 | 08:05 PM
Brian_TII's Avatar
Well... if the compression is actually OK... then it's not an apex seal. But if the car won't idle... and it sounds like horible... then it could be an apex seal. How does it sound when you are cranking it? Does it make the normal "Woo Woo Woo Woo" RX-7 sound? Or does it skip kinda?
Old Feb 10, 2002 | 11:15 PM
877's Avatar
877
She starts fine and idles smooth, just sounds underwater, as soon as she warms up it stalls. When I pulled the plugs the L1 &T1 were clean and others were black. I've been through most of the car recently checking all gadgets for emissions, air, fuel, ignition systems. Everything checks out ok. I must have missed something. All thats left are the water sensor thing and thermol sensor and thermostat. The last three things to check. Its driving me nuts. My gen. 1 NEVER died for this long and I blew the drive shaft right out of her once. These little things trip me up big time.
Old Feb 11, 2002 | 01:50 AM
Aico's Avatar
carbon builtup?
Old Feb 11, 2002 | 08:18 AM
877's Avatar
877
in the middle of the ATF trick.......I'll let you know if that did it.
Snook
Oct 8, 2015 10:09 PM
