ok im a newb but i need some help
Old Apr 7, 2006 | 12:18 PM
DropTop7's Avatar
first of all im newb to rotaries so i need some help with terminology like s5 tii and other stuff like that. second i have problems with my 88 convertible. it seems like the car is flooding a lot. it usually takes some effort to get it started and if i dont make it on the first try or so it just doesnt want to start of a few hrs. also i think the timming is off what is the procedure for setting the timming? also the car seems a lil low on power, maybe this is just because of its nearly 400lb handycap on the coupesbut still i think it needs more than that. i really dont want to put too much into the na engine because im told that a turbo II swap is a very good idea but id like it to run good untill i do that. any help would be great.
Old Apr 7, 2006 | 12:32 PM
Goofy's Avatar
Do a 60k tuneup if you haven't. Check spark plugs for fouling. Your injectors might be leaky.
Old Apr 7, 2006 | 12:39 PM
DropTop7's Avatar
just did plugs and wires, how do i check the injectors?
Old Apr 7, 2006 | 01:56 PM
Goofy's Avatar
From the FAQ stickied at top ( https://www.rx7club.com/2nd-generation-specific-1986-1992-17/frequently-asked-questions-2nd-generation-rx-7-faq-fc-494667/ )
I don't want to buy a shop manual for my car, is there a place where I can still find out the information from one
Shop manuals for both series can be found on-line at:
http://www.cochran-racing.com/FSM/index.html
http://208.62.166.66:82/guest/shop_manuals/
or (86-88)
http://www.teamfc3s.org/main/factor...nual/1986_1988/
and (89-91)
http://www.teamfc3s.org/main/factor...nual/1989_1991/
Should have info on injectors there. From what I understand, injectors are fairly cheap to get cleaned and blueprinted.
Go to search, advanced, search "clean injectors" in title only.
https://www.rx7club.com/showthread.p...lean+injectors
Old Apr 7, 2006 | 02:19 PM
mrtasty's Avatar
J-spec swap sounds good to, try Osaka if your interested
Sterling
60
Aug 4, 2005 12:58 AM
Fero313
Jul 29, 2003 04:28 AM
Questions
19
Mar 23, 2003 02:48 PM
prototype1369
Dec 27, 2002 09:34 PM
poor college student
16
Nov 25, 2002 01:05 AM
