¿volt meter needle jumping?
Old Apr 7, 2006 | 12:00 PM
RougeVisual's Avatar
Damn, its been a while, but i noticed yesterday that my volt meter was jumping from about 12 volts to about a little more than an eight above it. to give you an idea, if you have a fuel cut switch, watch the difference between when the pump is on and off.... so yesterday, i didn't have any time to check on it, so today i pop the hood when i parked at school, and one other note to have, no oil cap,( the threads on the neck are duller than a f'n bowling ball so the cap doesn't get on there nice and snug, i think i will just do what i did afte the first time it fell off and use zip-ties and aluminum foil.... but any way, any suggestions, i stripped the rear interior and i noticed that the wire to the fuel pump is twisted together and bare, fixing that today... but anything else i should check? thanks.........
p.s., i am making an fc3s info site.... rougevisual.com/fc3s
its not finished, but it should be by next wednesday... ok everyone, thanks.
Old Apr 7, 2006 | 12:44 PM
Icemark's Avatar
Anything under 12.6 volts and the car is running on battery power.
There needs to be at least 13.5 volts to charge the battery while the engine is running and 14.4 volts is the normal operating voltage for our cars with the engine running.
Old Apr 7, 2006 | 05:35 PM
hmmmmm..... thanks icemark....you should put up a paypal dontate a dollar thing... you would be rich.....anyway... thanks again... and if you or anyone else wants to look at my site check it out... but you should get firefox... its just like internet explorer but a billion times better... well, have you ever been to a website that is all messed up looking... it is because IE doens't support alot of the code for making a site.... but with fire fox everything is aok...... anyway... chek it out... i still plan on making links to the pages for the writeups and giving credit...... and more links to vendors and services...... but let me know..... and if you want your car on the gallery let me know...... other than that......thanks and later......
Old Apr 7, 2006 | 06:13 PM
gxl90rx7's Avatar
destroy, rebuild, repeat
I have a similar problem, the needle with dip down and back up again when putting it in reverse?
Old Apr 7, 2006 | 08:23 PM
Icemark's Avatar
www.mazdamark.com
dona1326cosprings7
Oct 29, 2015 06:47 AM
FC3S Timmy
16
Oct 3, 2015 01:08 AM
edgars95rx7
Link Vi-PEC
Oct 1, 2015 01:59 PM
Rotafuzz
Sep 30, 2015 09:55 AM
