BEst place to connect the FPR to?????????????
Old Apr 7, 2006 | 12:24 AM
Turbo II-FB's Avatar
whats tehbest place to connect teh vacum line for the fpr to
Old Apr 7, 2006 | 12:26 AM
kungfuroy's Avatar
Chicken Adobo
Doing a rats nest removal? Connect it to the original location where the fpr solenoid connects to
Old Apr 7, 2006 | 12:37 AM
uRizen's Avatar
XBL** Ownicus
I did the emissions removal awhile ago and left the solonoid in there connected to the same vacuum source it was using before.
Do people normally go with or without the solonoid after the removal? I've seen two N/A FCs running the FPR directly off of vacuum and that doesn't seem like the proper way.
Old Apr 7, 2006 | 12:39 AM
Node's Avatar
uRizen, thats the coolest avatar ive seen in a while.
Old Apr 7, 2006 | 12:41 AM
Node's Avatar
and back to the topic
RETed has some stuff about the fuel lines and aftermarket fpr's along w/ a different type of fuel setups (location of fpr and lines, etc etc)
www.fc3spro.com i think, might be .net or fc3s-pro.com. i forget, good site though.
Old Apr 7, 2006 | 11:06 AM
mine is the stock FPR
Old Apr 7, 2006 | 01:22 PM
Digi7ech's Avatar
I break Diff mounts
The solenoid just sets the FPR to atmospheric rate during start up to try and prevent flooding.
I ran it for a few months and found it did nothing beneficial. I removed it and it's running the same. A fuel cut switch is much better.
You should get vac from the original source.
Here is my old vac diagram so you can see where to get it.
Old Apr 7, 2006 | 01:28 PM
88rxn/a's Avatar
tom port.. AKA streetport
good job
Old Apr 8, 2006 | 01:32 AM
NZConvertible's Avatar
I'm a boost creep...
Assuming this is a Turbo (since no car info was given), the FPR is normally fed from the angled nipple on the inside of the LIM.
Old Apr 8, 2006 | 08:45 AM
uRizen's Avatar
XBL** Ownicus
Sweet, that's one less line and thing I can yank out of there, thanks!
Old Apr 8, 2006 | 08:59 AM
rotorforce's Avatar
I'm back Bishes
Medevack1
Naturally Aspirated Performance Forum
13
Nov 10, 2017 04:53 PM
tidanb0utch
11
Oct 7, 2015 07:36 AM
blackball7
34
Sep 16, 2015 10:10 AM
