questions questions questions
Old Apr 6, 2006 | 10:43 PM
88durel's Avatar
Shaolin7
hey guys heres a list of the most recent questions that i need help with...
1. how can i jump my passanger window switch to run just off the drivers window switches,,, until my new switch gets here.. lol
2. if i get a plug and play megasquirt... then decide to turbo my car... will the megasquirt notice the +psi and modify my a/f mixture?
3. to pop open my sunroof and close in manually. i need an allen rench on the bold under the motor? correct me if im wrong?
4. a stock n/a rx7 injectors and drivetrain can hold a save 190 hp?
i sappose thats it for now
thanks guys,,,
another faithful rx7 owner
sence july 2005...
88Durel
Old Apr 7, 2006 | 01:27 AM
Icemark's Avatar
1: if the passengers switch is in there, it is already jumpered. Not being touched, the switch is bypassed.
2: not without changing programing
3: yes
4: the stock non turbo injectors can support 220-225 HP, the drive train is more based on torque.
Old Apr 7, 2006 | 04:05 PM
88durel's Avatar
Shaolin7
if its already jumped when not activated via drivers switch,..,... then i must have another problem.... because even using the drivers switch, the passangers wont roll down.... it appears that there is a piece missing in the passanger side, because its has no resistance on the actuall switch, its like a piece broke on the inside... when i pull the switch out, i have four leads and 2 lower leads
O.O
O'O
can anyone help me with a solution?
Old Apr 15, 2006 | 09:16 PM
88durel's Avatar
Shaolin7
anyone know what might be wrong with that switch>? no power to any of the wires...
_Tones_
May 25, 2021 05:37 AM
Nosferatu
Sep 5, 2015 02:13 PM
