86 car has no spark
Old Apr 5, 2006 | 11:55 PM
justincue's Avatar
86 car has no spark
The car has sat for two days. So time to go for a drive and the car sounds like it is flooded. So i do everything unflooded techique short of taking the motor out and the car still doesn't start. It doesn't even want to, it just cranks and cranks...
So i took the plugs out of the block and hooked the spark plug wires up to the plug and grounded the plugs and still no spark..
i have ran all the wiring for the fuel and electrical and found nothing.
changed ecus
compersion check(good)
checked relays
any other ideas?
Old Apr 6, 2006 | 12:44 AM
Icemark's Avatar
what was the numbers of the compression check, and were the spark plugs wet when you pulled them??
Old Apr 6, 2006 | 08:25 AM
justincue's Avatar
they were both around 100 and the plug were not wet.....
but the non wet plugs could be from thinking it was flooded.(took out the fuel fuse for a while)
Old Apr 6, 2006 | 11:12 AM
swbooking's Avatar
The Never Ending Project.
bu they should be wet if you replaced the EGI injection fuse and cranked it, if their not seems like a fuel problem... maybe your pump...
Old Apr 6, 2006 | 11:13 AM
Icemark's Avatar
They would be wet if they were not sparking...
so if they are not wet, then you are not getting gas.
BNR34RB26DETT
42
Feb 28, 2018 11:27 AM
alphawolff
Nov 17, 2015 05:57 PM
highspeedrider
Sep 8, 2015 07:55 PM
cam_7779
Aug 18, 2015 07:48 AM
