Other Engine Conversions - non V-8 Discussion of non-rotary engines, exc V-8's, in a car originally powered by a Rotary Engine.
Top Speed Calculator Here!
Old Apr 5, 2006 | 07:54 PM
cabe's Avatar
I was reading another thread and got motivated to make this. I figure that someone can make use of this, so here it is!
It calculates theoretical top speed based on tire size and engine RPM. Just fill in the blanks!
File Type: zip
Old Apr 5, 2006 | 10:19 PM
eastcoastbumps's Avatar
Your tire size is mis-calculated. The 40 in 225/40/18 is the aspect ratio. Its the ratio between the sidewall and tire width. So a 225/40/18 has a 90mm sidewall. (225mm x 40/100=90mm) So a 295/30/18 has a 88.5mm sidewall and a 295/40/18 would have a 118mm sidewall.
Old Apr 5, 2006 | 10:27 PM
And another thing, 6th gear is so tall that you cannot accelerate after you upshift at redline in 5th gear in a Corvette or F-body. So their top speed is at redline in 5th. I'm not sure how it would work out with a 4.10 in an FD, or an LSx making more power than stock.
Old Apr 5, 2006 | 11:56 PM
cabe's Avatar
Fixed to reflect your input, thx for the correction!
File Type: zip
Old Apr 6, 2006 | 10:54 PM
Thanks for doing this. Its actually pretty cool. I don't think I'll be able to test the 6th gear pull after a shift at redline in 5th. Anyone crazy enough to try?
Donald Hampton
16
Nov 23, 2022 06:38 PM
MazdaspeedR1
The Bad & Fugly Businesses
27
May 22, 2018 05:58 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
