Can this be done without screwing up the F-con???
Old Apr 5, 2006 | 12:40 AM
FC3S Murray's Avatar
5 and counting.
Ok, I am putting in my new S5 street ported engine in tommorrow and am concerned about the pushing the factory injectors way past thier limit with the new ports. I am running a hybrid S5 turbo(only gonna push 10 to 12lbs), RB turboback exhaust, HUGE fuel pump, F-con with GCC, AEM wideband and much much more. The ECU system is a S4. The question I want to know is if I can put in 720cc for secondaries and still run the f-con. HKS says no but if I got this right, the impedence on the factory and 720's injectors are the same and the only difference is the amount expelled by the injector at "Static" so would the f-con perform the same? I know the f-con adjusts the fuel curve due to higher boost but if the resistance is the same no harm done right? I just blew my engine last Dec due to detenation, I dont want it to happen again, hurts the wallet!
Old Apr 5, 2006 | 01:01 AM
5 and counting.
Anyone??
Old Apr 5, 2006 | 03:50 AM
myfc3s's Avatar
That's what she said...
I suggest put some 680cc from the gsl-se. They work great when i used them way back, when i used the F-con.
Old Apr 5, 2006 | 07:44 AM
rotorforce's Avatar
I'm back Bishes
720's are fine with the F-con. Had it on my 87TII with a larger turbo and mild bridgeport. The only problems I ever encountered was boost creep due to the size of the ports vs the size of the turbo (to4e) but the fuel delivery was not a problem provided I could keep the boost at around 10psi (which was almost impossible).
Make sure you upgrade your fuel pump, and change out your fuel pressure regulator to an aftermarket.
Andrew7dg
Aug 6, 2017 01:41 PM
Chiaszy
Sep 23, 2015 01:43 PM
