Need help choosing correct wastegate springs
Old Apr 4, 2006 | 10:48 PM
Turbo_Rotary's Avatar
Major RX-7 Withdrawals
I just ordered a fully divided turbo manifold with dual wastegate runners. I'll be running dual Tial 38mm's, but I am a little confused on which springs I need to run in both. Will both wastegates see the total amount of boost (~23 psi), therefore needing the larger springs, or will both wastegates see only half the boost (~12 psi), needing only the smaller spring?
Old Apr 5, 2006 | 02:14 AM
RenofHeavens's Avatar
Famous Phil's Cheesteaks
Try the single turbo section for better answers.
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
Shainiac
Jul 17, 2019 02:20 PM
