noz
Old Apr 4, 2006 | 07:48 PM
drft5150's Avatar
Exclamation noz
im thinks on buying a 50 dry shot id like to know if it will work with out any big problems and whats the diff is and what would i need to make it wet?
Old Apr 4, 2006 | 08:35 PM
rotarymarine's Avatar
Rebuilding the 7
truly i know nothing about installing nitrous on an rx but i know that the diff between wet and dry is the injection of nitrous and fuel at the same time on a wet kit virsus a dry kit where just nitrous is injected.
Old Apr 4, 2006 | 08:59 PM
wayfastwhitey's Avatar
a 50 h.p. dry system should cause no major problems if u have a healthy fairly low mile rotary the risk goes up with the more wear on ur engine. how many miles on engine????
Old Apr 4, 2006 | 09:01 PM
SwiftTone's Avatar
Wet is the way to go. Fuel is added to compensate for the nitrous.
Old Apr 4, 2006 | 09:02 PM
Jager's Avatar
Tear you apart
Buy a wet shot first. No need for a dry shot in this car.
A 50 shot you can run on stock timing, get a FD fuel pump and a FPR (so it doesn't run rich at idle), and then the rest is worrying about your clutch.
CyborgRyu
Racing Kills Lounge
14
Sep 21, 2008 02:11 PM
honda's nightmare
30
Jul 5, 2006 11:14 AM
