Haltech BAC valve needed for my haltech?
Old Apr 3, 2006 | 10:07 PM
GOTBANNED?'s Avatar
Boost Addict
Do i need this? I blocke dit off since i don't have A/C i took it out so no need to up the rpm when i turn it on. So is there any need for it?
Old Apr 3, 2006 | 10:32 PM
Claudio RX-7's Avatar
EFI Tech Wannabe
If you took the A/C out hardly, but for cars that have power steering and A/C its needed to keep the idle steady.
Old Apr 3, 2006 | 11:18 PM
GOTBANNED?'s Avatar
Boost Addict
I have power steering so do i still need it or can I remove it. I have seen a number of guys that remove it.
Old Apr 5, 2006 | 11:58 AM
crispeed's Avatar
'Tuna'
Not neccessary needed for P/S. If anything if you desire would be for cold start.
Old Apr 5, 2006 | 10:30 PM
RETed's Avatar
It's really not necessary if you adjust the throttle stop for about a 1,000RPM idle.
Even at 900RPM, it should not die on you if the tune is good.
The BAC valve just gives you a solid idle under any conditions once the parameters are adjusted correctly.
Not necessary, but it does showcase your tuning skills - it's bragging rights.
-Ted
Old Apr 5, 2006 | 10:55 PM
GOTBANNED?'s Avatar
Boost Addict
well steve kan will be tuning it
Old Apr 6, 2006 | 02:36 AM
RETed's Avatar
I'd consult Mr. Kan with your queries.
I'm sure Mr. Kan has no problem going either way.
-Ted
smikels
Rtek Forum
May 12, 2016 12:34 AM
befarrer
Microtech
Aug 22, 2015 05:52 PM
86rxNa
Aug 11, 2015 11:51 AM
