use gasket sealer?
use gasket sealer?
I am changing both of the gaskets and o-rings on my lower intake manifold.
Do people recommend using some gasket sealer on the gaskets? How do the proffessionals do it? cause i REALLY dont want to be doing this job again
reply, you know you want to
s5 13bt
s5 13bt
put a tin layer of silicon on both sides of the gasket, it will seal it from haveing little leaks and if you have to change it again it wont stick, so you wont have to scrape it
mike
mike
matty
40
Oct 6, 2015 09:13 PM
