What are these?
Old Feb 9, 2002 | 09:03 PM
J-Rat's Avatar
Alcohol Fueled!
What are these?
What are these???
Old Feb 9, 2002 | 09:04 PM
J-Rat's Avatar
Alcohol Fueled!
this too
and this
J-Rat's Avatar
Alcohol Fueled!
here is the whole assembly
Old Feb 9, 2002 | 09:06 PM
J-Rat's Avatar
Alcohol Fueled!
this too
last one
Old Feb 9, 2002 | 10:59 PM
j9fd3s's Avatar
Community Builder
Re: this too
Originally posted by J-Rat
last one
the red one is the fast idle cam the thing its pushing on is the thermowax, this is what gives you a fast idle when the engine is cold.
the other thing is the dashpot it keeps the throttle blades from snapping shut a) to reduce wear on the throttle shafts and b) for emissions between shifts
mike
Old Feb 10, 2002 | 04:34 AM
J-Rat's Avatar
Alcohol Fueled!
thanks!!!!
Old Feb 10, 2002 | 05:19 AM
HAILERS's Avatar
HAILERS
Page 4A-56 of the online manual at http://www.iluvmyrx7.com/Technical_I...ice_manual.htm When you understand the relationship of the thermowax and the fast idle cam (and the throttle stop screw that they never ever mention), you can see why you have to have the car at full warm before setting the tps. You can check the thermowas by pouring boiling water over it and watching the piston extend and retract with temperature.
Old Feb 10, 2002 | 05:35 AM
J-Rat's Avatar
Alcohol Fueled!
Thanks HAILERS..I was curious as to wether or not there were some adjustments I could do before I put the top half back on....
Rat
