Corvette Electric Airpump Doesn't work for 6ports or VDI
Old Feb 9, 2002 | 02:22 PM
Silver88GXL's Avatar
For those that are curious about using an electric airpump to run the 6ports or VDI, I have some results.
I picked up a Corvette Airpump according to Brian Cain. The problem is that it just puts out air, no pressure of any significance. I think it puts out maybe a pound and a half. So, what I am doing is modifying the VDI actuator so and removing the spring and replacing with a weaker spring. I will get some pictures when I am complete.
The VDI requires less pressure to operate than the 6ports, so I will have to see if I can get the same results from the 6port actuators.
Carl
Old Feb 9, 2002 | 03:57 PM
No7Yet's Avatar
Very interesting and Kudos for taking on a project that the N/A guys have wanted for a long time!
The VDI and 6PI actuators are VERY similar in their design. The "weak spring" method should work just fine but keep us informed!!!
Brandon
Old Feb 9, 2002 | 04:30 PM
i read somewhere that a guy used a airpump from the air suspension system on the earlier year caddy's...not really sure wich years,but,i was gonna see if i could find 1 down the road for my vdi...they might have a bit more pressure,anyway.
~d
Old Feb 9, 2002 | 06:05 PM
Scott 89t2's Avatar
SOLD THE RX-7!
cain's vette airpump was to pass emissions, he had no intentions of making 6-ports work since his car is turbo....
if you want it to work check here
www.fc3s.org in the how too's--> electric
wait why are you doing this on an 88? there's no vdi. different car then name?
Old Feb 10, 2002 | 12:21 PM
I understand the reasoning for using the pump on his car, but I was hoping that it would put out enough pressure to run the VDI and/or 6ports.
I do have a VDI on my car. I performed the intake manifold swap. It seems that I have been one of the few, if any, to see any substantial gains from the swap.
Carl
Old Feb 10, 2002 | 03:04 PM
von's Avatar
von
Silver88GXL.. IF this vdi thing works make sure to post a new thread. Im itching to get some low end back... Isnt the vdi also activated electronically? And can I get an electric pump off any corvette????? Give me some specifics please. THXN
Old Feb 10, 2002 | 04:08 PM
I will definatly do that. So far, I think it will work. All I needed was a weak spring to get the diaphram to close back, and I think the secondary springs from a Holly Carb will do that, but still be weak enough not over power the air pump. If it works, I will post pictures of what I did.
The air pump I purchased was from a 97 Corvette. Pretty much any late model Corvette, Camero, or Impala has it. They aren't cheap though. I got a great deal on mine since I work for a dealership, but they list for 170-190. Cheapest I saw on the internet was 130 from a place that said they were 15% over dealer cost.
Carl
streetlegal?
Mar 17, 2022 02:46 PM
rexhvn
Aug 19, 2015 02:59 AM
