Timing Question
Old Feb 8, 2002 | 07:06 PM
fasthack's Avatar
Timing Question
I am at the point where i am going to experiment with my timing to see if i can yield a few hp's. I am pretty sure that it is set at stock right now(i have never messed with it) and i just want to nudge it forward to see if i can feel a little power inrease. How can i do this, i took a look at it earlier today and i am not sure how to do it. Thanks guys...
Craig
Old Feb 9, 2002 | 12:10 AM
hypntyz7's Avatar
To adjust timing loosen the 10mm nut on the CAS(left side front of engine, flat black top). Clockwise rotarion is advancment, CCW is retard. Stock setting(if timng light is unavailable) is about 3-4mm from the edge of the left side of the oval slot. IT should appear that the bolt is 1/3 of the distance from the lefthand edge of the slot to the right edge of the slot. Ive found its safe to advance timing as far as 3-4mm from the righthand edge of the oval slot. Be advised this is dangerous, can lead to detonation and overheating quickly.
smikels
Rtek Forum
May 12, 2016 12:34 AM
alphawolff
Nov 17, 2015 05:57 PM
CaptainKRM
14
Aug 26, 2015 09:52 PM
