Engine Airflow Calculator for purposes of Turbo Selection based on Fuelflow and AFR
Old Mar 23, 2006 | 01:15 PM
pistonsuk's Avatar
I would like some constructive criticism on this engine airflow rate calulator I made for choosing the best compressor map. It will give the corrected airflow rate in lbs/min based only upon:
1) Fuel flow
2) AFR
3) Ambient temperature
It opens in Excel.
http://usu.edu/~jgastrich/EngineFlowCalc.xls
Will this predict the current airflow rate of the engine within the uncertainty of your injectors and your air/fuel meter? If so, this seems like a better bet than guessing your VE like an many calculators I have seen. Are there any other variables I'm missing?
Justin
Old Mar 28, 2006 | 06:53 AM
bump
Old Mar 28, 2006 | 08:52 AM
Howard Coleman's Avatar
Racing Rotary Since 1983
nice job.
it seems to work right for me and tends to confirm a formula i have used re airflow and turbo sizing.
as far as constructive criticism...
since the power fc/datalogit reports boost and AFR differently than your table which uses psi and the AFR ratio... might you build in a formula so you could cut and directly paste the relevant data?
howard coleman
Old Mar 28, 2006 | 09:47 AM
rrussell's Avatar
Very Nice! I will be using it.
Old Mar 28, 2006 | 01:34 PM
pistonsuk's Avatar
howard coleman
I purposely left the columns to the left for users to enter whatever formulas they wanted depending on what data they have actually logged.
Send a Power FC datalog to rotor_rage@yahoo.com for me to look at. Maybe I will make one of the Datalog worksheets Power FC specific.
Justin
Old Jun 9, 2006 | 01:24 AM
evelhalo's Avatar
HEY, know youre a turbo guy bu any idea where to find a chart like this for n/a??
Old Jun 16, 2006 | 10:23 PM
pistonsuk's Avatar
This works with turbo or n/a. It simple looks at fuel flow and AFR. As long as you are datalogging these two parameters you can calculate your mass flowrate of air.
Justin
Old Jun 24, 2010 | 10:38 AM
Wo:Deep's Avatar
DAMN!Nice
link no longer working....
Engine Management Forum
11
Nov 9, 2015 01:15 PM
Microtech
Aug 23, 2015 11:04 AM
ChrisRX8PR
Aug 21, 2015 01:56 PM
20B Forum
Aug 19, 2015 01:47 PM
