5 bolt to 4 bolt conversion
Old Feb 8, 2002 | 11:12 AM
dwillms's Avatar
I have a 87GXL and want to put my 86 GX 4 bolt pattern on it so i can fit my 4 bolt mags on my new gxl that has 5 bolts. Whats involved in this procedure - how do i do it and do i need any special tools?...and will it make a difference in performance?
-Daryl
Old Feb 8, 2002 | 11:30 AM
SirRX7's Avatar
Epitrochoid Knight/Mod
WOW!!!, This has been a week of firsts. Earlier someone wanted to remove their 89+ taillights and replace them with 87 taillight and now you want to ditch the 5 bolts for 4. I'm freaked out. Good luck.
Old Feb 8, 2002 | 11:35 AM
Yeha itll make a difference. You are going from vented rear brakes to solid rear brakes (bad) and from 4 piston front calipers to 1 piston front calipers (worse) Expect worse braking woth mroe fade and less modulation.
Old Feb 8, 2002 | 12:05 PM
SpeedRacer's Avatar
Formula Mazda Driver
You will need to replace the whole hub assemlby, and everything outwards from there. You should be able to keep your rear-caliper, but if you front 4-piston calipers, you will need to ditch those. You will also need to replace the rotors up front. You might be able to keep the rear-rotors from the 5 lug. I personally think you should get new rims though rather than this conversion.
Old Feb 8, 2002 | 01:31 PM
RETed's Avatar
Firs, are you sure that 4-bolt rim will fit?&nbsp The stock 4-bolt pattern for an FC is 4x114.3 - this is not a common bolt pattern nowadays.&nbsp If you're looking to swap in a set of rims from a Honda (4x100), it's NOT GOING TO FIT!
-Ted
Old Feb 8, 2002 | 01:41 PM
SpeedRacer's Avatar
-Ted
I think he already has rims from his 86 4 bolt, that he wants to put on his 87 GXL.
Old Feb 8, 2002 | 01:44 PM
RETed's Avatar
Oops, too early in the morning for me!
-Ted
Old Feb 8, 2002 | 06:07 PM
peejay's Avatar
Old [Sch|F]ool
Almost all racing wheels are available in that pattern. It's also known as 4 on 4.5" the same as Mustangs (and lots of other Fords) and Nissans have used for ages.
Old Feb 8, 2002 | 07:18 PM
RETed's Avatar
Mustangs have all been 5-bolt since 1993(?).
Nissan (240SX) dropped the 4-bolt pattern when swapping over to the S14.
Almost every "sporty/sports" car today runs 5-bolt.
-Ted
Old Feb 8, 2002 | 07:44 PM
peejay's Avatar
Old [Sch|F]ool
Yes but most of the Mustangs being raced are still 4-lug
4x4.5 is probably the second most common 4-hole pattern right behind 4x100... heck it might even BE the most common... I have a much easier time finding wheels in 4x4.5 than 4x100, 'course I'm not looking for appearance wheels either.
Vartok
Sep 24, 2015 02:20 PM
