GSL-SE Windshield Wipers
Old Feb 8, 2002 | 11:02 AM
Condores's Avatar
Windshield wipers on my GSL-SE are not working.
Wondering if anyone of you experts out there had experienced the same problem and can share your expertise/recommendation as to how to go about fixing the wipers.
Thanks!
Old Feb 8, 2002 | 11:07 AM
1stand3rd's Avatar
Not working as in how?
Not turning on at all?
The wipers on my 85 GSL were moving very slowly and making a grinding noise. It appeared the motor was frozen, so I bought a used wiper motor from Sun Auto and replaced it.
Great service ---> http://www.sunautorx7.com/
If they're not working at all, check your switch or fuses.
Old Feb 8, 2002 | 11:16 AM
Condores's Avatar
Not working at all.... The fuse is fine.... How much did you pay for the motor?
Old Feb 8, 2002 | 11:21 AM
1stand3rd's Avatar
I don't remember exactly, but I think it was around $100. Everything was included except the wipers themselves (motor, linkage arms, etc).
The motor arrived within a week.
All I had to do was remove the cowling on the hood, then remove and replace the motor.
Before springing for a motor, make sure that's what it is. I wouldn't know, but are the switches
known to go bad on the SE's?
Pat
85 GSL
93 VR Touring
Old Feb 8, 2002 | 11:33 AM
MyRxBad's Avatar
EliteHardcoreCanuckSquad
Take the front cover off (the one between the windsheild wipers with the venting in it) There is the obvious wiper bolts plus bolts along the firewall (top where the hood sealer is)
Then unplug the wiper motor and check for power when the switch is on. If theres power to the motor then the switch is fine.
Check the connector on the arms (similar to the one on the headlights) they break easily and the arms fall off. If that's not the case then it's probably the motor. If you want to test it, put 12v to it and see if see moves.
Old Feb 8, 2002 | 01:25 PM
HOZZMANRX7's Avatar
Driving RX7's since 1979
The wiper motor, pivot arms, etc are generic to all 1st Gens. So, easy to find a junk yard replacement. My bet is the motor is bad.
Old Feb 8, 2002 | 02:33 PM
Tigger09's Avatar
Let me know if you need a new one, I can get you abetter deal than $100.
Jim
Tigger09@theimperials.net
Old Feb 8, 2002 | 02:37 PM
Felix Wankel's Avatar
Super Newbie
Take the wiper assembly out and unbolt the arm coming from the motor. Try to move the assembly. I bet the linkage is frozen. WD40 the hell out of it and it should work. Lube the pivots with white lithium so it doesn't seize again.
Old Feb 8, 2002 | 03:02 PM
1stand3rd's Avatar
In my case, I did the WD40 trick on the linkage, but it didn't matter. The 'moaning' was coming directly from the motor.
I called Sun Auto as a last resort.
Are you sure you want to put lithium on the linkage? Won't that attract alot of dirt/dust?
Old Feb 8, 2002 | 03:10 PM
Super Newbie
I dunno. I just had to do something because Rain-X sucks at under 30 mph.
Old Feb 11, 2002 | 12:00 PM
Condores's Avatar
Thanks! I'll be trying all of your recommendation soon and will let you know the outcome....
Old Feb 11, 2002 | 05:26 PM
RotorMotorDriver's Avatar
Seven Is Coming
Anyone know what size the blades are on the GSL-SE? I got some that Schucks said would fit but there too big and they only had those in their computer thing on the rack...
~T.J.
Old Feb 11, 2002 | 06:58 PM
Super Newbie
~T.J.
I think they are 17''
Old Feb 12, 2002 | 09:08 AM
cjf's Avatar
cjf
Iagree...17" is stock but you can put 18" on with no problem...I have 18" on mine...but hey,,,maybe 20" or 21" will work too...
Old Feb 12, 2002 | 09:09 AM
cjf's Avatar
cjf
hey condores, you know where you can get the motor if you want it...cjf.....................
NickNac113
13
Oct 1, 2015 09:25 PM
