Haltech water temp and air temp sensors
Old Mar 15, 2006 | 01:34 AM
gonzz's Avatar
I just bought these at autozone today. I found a post saying these will work.. Anyone else using these? Both are 3/8" NPT
GM part # Air Temp Sensor; 25036751
Water Temp Sensor; 15326386
Old Mar 15, 2006 | 12:18 PM
yusoslo's Avatar
I have injector envy!
I bought that same air temp sensor part number from autozone and it was huge! like 5/8" or something. I couldnt even find a tap large enough to make it fit in the TB elbow, so I jamed it into the silicone elbow of the top mount and it works great.
Old Mar 15, 2006 | 12:38 PM
Claudio RX-7's Avatar
EFI Tech Wannabe
The Haltech provided air and coolant temp sensors are delphi sensors, ie. GM, you part numbers seem right, the tap needed for them is called 3/8" NPT, it is fairly large.
Old Mar 15, 2006 | 03:09 PM
yusoslo's Avatar
the one I got in the NAPA cross refrence manual said the sensor was a 3/8" 18 thread sensor. But the one I actually got was much larger even though the part # was the same, oh well.
Old Mar 15, 2006 | 06:07 PM
tims's Avatar
3/8" -18 is the same as 3/8"NPT,18 is the thread count. NPT=national pipe thread. got to a plumbing supply of good tool supply and ask for a 3/8"NPT tap. it is much larger than a 3/8" bolt. it is a tapered thread not a straight thread like a bolt. it is used in pipe fittings and is very common.
Old Mar 15, 2006 | 09:31 PM
yusoslo's Avatar
thanks that was very helpfull.
Microtech
30
Apr 23, 2016 06:37 PM
immanuel__7
89
Sep 5, 2015 10:23 AM
befarrer
Microtech
Aug 22, 2015 05:52 PM
