Haltech e6x idleing 100cc injectors
Old Mar 13, 2006 | 06:08 PM
turbine's Avatar
is any one doing it
Old Mar 13, 2006 | 08:07 PM
turbine's Avatar
woops, posted that in a hurry.
i wanted to know if any one is using 1000 cc injectors for there primaries with good results
any idling issues
thanks tyler
Old Mar 13, 2006 | 09:46 PM
Claudio RX-7's Avatar
EFI Tech Wannabe
Why would you use 1000cc as primaries? what are you using (or want to use) as secondaries?
At any rate, yes, you can get 1000cc injectors to idle.
Old Mar 13, 2006 | 09:59 PM
turbine's Avatar
[QUOTE=Claudio RX-7]Why would you use 1000cc as primaries? what are you using (or want to use) as secondaries?
because i have an extra set laying around and i need to get my 550 primaries cleaned. so i thought why spend 50 bux when hey i could toss in the thousands
i am running 1600 secondaries.
over kill, yes but isn't that what we are all about.
i was just wondering if anyone using 1000 cc primaries are having any idling issues
thanks tyler
Old Mar 13, 2006 | 11:07 PM
crispeed's Avatar
'Tuna'
[QUOTE=turbine]
thanks tyler
1000cc's with a Haltech should not be a problem
I have seen them idle with 1600cc's. Everyone's idea of a clean idle is different. Also the type of porting makes a difference.
I've always been able to support 580 to 600 RWHP with a 720/1600cc combo.
I have a13B right now idilng at 13.5 A/F with 1600cc's in it. With the right ecu and tuner anything is possible.
barkz
Power FC Forum
37
Nov 21, 2020 09:34 AM
bryancmatthews
Power FC Forum
14
Oct 5, 2015 08:49 PM
ZacMan
Sep 19, 2015 09:20 PM
