Fuel map adjustments
Old Mar 13, 2006 | 02:19 PM
mjw's Avatar
mjw
Just curious where you guys with experience begin in adjusting your fuel maps after going with a larger turbo. For example, I've gone from a TO4E to a TO4S..
seeing that the TO4E flows 53lbs/min. max and the TO4S is at 60 - 61lbs/min max. I'm looking at about a 15% increase in airflow, this seems to hold true when comparing dynos as well.
I thought that I would spread that 15% increase out between 0psi/low rpm (where spool would start) and about 15psi/5500 rpm (peak torque), does this seem to make safe tuning sense? Adding 15% across the entire boost map seems heavy handed and overkill.
Thanks for any help.
Old Mar 13, 2006 | 07:20 PM
mwatson184's Avatar
holley guy
You shouldn't need to adjust even close to 15%. The flow of the turbo is limited by the RPM/port style of the motor. The turbo may be capable of flowing more, but it won't do so unless the boost, RPM, or VE is increased. The different efficiency at a given boost level may cause a slight difference in the amount of total airflow, thus needing some sort of fuel adjustment. Increasing the fuel across the board is a good safe way to start, then lean out until the desired AFR is reached.
-Marques
Th0m4s
Feb 26, 2019 02:04 AM
Skeese
65
Mar 28, 2017 03:30 PM
Microtech
30
Apr 23, 2016 06:37 PM
sen2two
AEM EMS
Oct 23, 2015 07:51 PM
