86-88 have less hp?
Old Feb 6, 2002 | 07:56 PM
böst's Avatar
86-88 have less hp?
Why do the earlier turbo II's have less hp?
Old Feb 6, 2002 | 07:58 PM
RETed's Avatar
Less compression ratio - 8.6(?) versus 9.0
Less boost - 5.5psi versus 7.5psi
Crappy turbo/manifold design
-Ted
Old Feb 6, 2002 | 08:12 PM
böst's Avatar
Wouldn't you want lower compression if you're going to boost the bejesus out of it? Or is that not the case with rotaries?
Old Feb 6, 2002 | 08:19 PM
Node's Avatar
stock boost does not qualify as bajesus
its more of a safety measures, higher compression still makes more hp, just isn't good for boost.
But Series 4 (86-88, actually Turbo 2s were only 87+) were lighter, and actually have a better lbs/hp ratio
maxim
Feb 5, 2002 10:01 AM
Agent_D
Feb 2, 2002 11:44 PM
Canibus
13
Dec 13, 2001 04:43 PM
vaughnc
Dec 12, 2001 11:01 AM
Canibus
Dec 9, 2001 09:35 PM
