FMIC help
Old Mar 7, 2006 | 06:54 PM
1QK7's Avatar
FMIC help
Im in the process of selcting which FMIC to use with my apexi rx6 turbo kit. Ive narrowed it down to the greddy two row or the greddy three row. Im going to keep boost under 15 lbs. Which kit should I go with? What is the diffrence between the two?thanks
Old Mar 7, 2006 | 07:22 PM
red87tll's Avatar
needs a cheaper hobby
Bigger is better?
Old Mar 8, 2006 | 10:56 AM
1QK7's Avatar
no replys? come on guys need some info here.
Old Mar 8, 2006 | 11:04 AM
Heisenberg's Avatar
Civilization is crumblin
If im not mistaken i remember reading the greddy 2-row is most efficiant around 15lbs of boost. I dont know what the 3-row is like but i would imagine its more than 15lbs.
Old Mar 8, 2006 | 11:33 AM
88t2romad's Avatar
(_8(|)
Same as ive heard, and i have the greddy 2row.
Old Mar 8, 2006 | 11:55 AM
chinaman's Avatar
2 row is like an upgrade for the stock turbos (not too high boost like the other guys have said). 3 row for single turbo with higher boost and for when you plan on leaving Porsche drivers and the like scratching their heads, wondering what just passed them.
Old Mar 10, 2006 | 09:56 AM
charlies7's Avatar
3rd rotors a charm
blitz or apexi
Old Mar 10, 2006 | 02:03 PM
willjs7's Avatar
3 and the hit for $100?
go with the 3 row... u wont realize too much of a difference at the psi, but when(if) you upgrade you wont have to buy another IC.
Old Mar 12, 2006 | 12:33 AM
NuTbAgSaN's Avatar
triangles
well if you stay 15 or less 2 row would be fine...but i would say 3 row in case you want to go higher down the road and it couldnt hurt anything...BUT wouldnt the easiest settup be to use the apexi ic?
Old Mar 12, 2006 | 09:57 PM
TT_Rex_7's Avatar
What's the core size on the Greddy 3 row?!
-Alex
Old Mar 12, 2006 | 10:01 PM
1QK7's Avatar
Not sure the core size but I went with the greddy 2 row. The 3 row is the same physical measurment as the 2 row but the 3 row is 2 inches thicker. Went with the 2 row because im not going to be going over 15 psi and did'nt want to deal with the extra thickness on a hot summer day in san diego. @ row is rated up to 18 psi and the 3 row is rated 15 psi and above. Quoted from greddy. Thanks fors the input.
Old Mar 12, 2006 | 10:07 PM
GUITARJUNKIE28's Avatar
multipersonality disorder
tall and wide is better than short and thick.
Old Mar 12, 2006 | 10:40 PM
TT_Rex_7's Avatar
I thought the 3 row was 4.5" thick. If a 2 row is 3", then that would make a 1 row 1.5", therefore a 3 row would have to equal 4.5" thick.
At any rate, if the 3 row is the same width and height, then what's the size of the 2 row!?
-Alex
