noobie here
Old Mar 5, 2006 | 03:03 PM
rejekt's Avatar
Newbie
noobie here
hey was wanting to ask you guys a question, i'm buying a 87 rx 7 tuesday, and it's been swapped with the 13bt engine, well the swap is almost done, and the only thing that needs to be installed before it's completely done is insstalling the intercooler, the radiator, the air box, and the oil coolant line., i was wanting to know if these were a hard install or a simple install. did you have any snags with it or did it go smooth.
Old Mar 5, 2006 | 06:27 PM
dhahlen's Avatar
FD Under Construction =P
wow 3 posts...
I'd just jump into it... the install is obvious.
The intercooler is easy if the piping and brackets have already been made. Fabbing up brackets and pipes aren't easy if you don't have the tools, lol.
The radiator also requires certain mounting brackets... the oil coolant line you are talking about doesn't make sense to me... what is an "oil coolant line" ? Is it an oil line, or coolant line? The air box is take... but if it's a turbo, there is not going to be an 'air box' that gets replaced with the turbo's air inlet filter.
These are things you'll have to figure it out on your own. Easy or Difficult depends on how mechanically inclined you are...
BobEmb
Comments and Suggestions Archive
11
Oct 14, 2008 01:27 AM
slug420
May 12, 2002 09:17 PM
