good upgrades-for stock fc
Old Mar 5, 2006 | 12:06 PM
TeAm-FaTaL's Avatar
I HAVE A STOCK 1986 MAZDA RX7 FC3s AND IT HAS ABOUT 135,500 MILES ON IT....WHAT ARE SOME GOOD UPGRADES THAT I COULD DO FOR MY CAR.....I MIGHT NOT BEABLE TO DO THE TURBO CONVERSION DO TO MONEY PROBLEMS SO NOW I NEED TO RELY ON ALL MOTOR.......SUGGESTIONS
Old Mar 5, 2006 | 12:10 PM
Eternal_Gamer's Avatar
intake exhaust. good luck because rx7 performance aint cheap at all, and upgrading a NA to satisfy your needs is harder than a turbo.
Old Mar 5, 2006 | 03:28 PM
diabolical1's Avatar
start with a full tuneup and change all fluids
get an exhaust system, and please note that that does NOT merely mean "ungodly large mufflers or tips" - get a system.
get good brakes!!!! (lines, pads, fluid and tires)
search for any intake and throttle body mods you can find
tighten up any slop you can find (i.e. motor/transmission mounts, suspension)
clean the engine (Amsoil Powerfoam or equivalent)
lightweight flywheel
should result in an appreciably different car.
Old Mar 5, 2006 | 09:20 PM
TeAm-FaTaL's Avatar
what type of exhaust system and flywheel would you preffer????my car came w/ custom headers when i bought it and thermocover and the guy did something with the egnition also....but like i said, what type of product would you recommend and where could i find them.....
Old Mar 10, 2006 | 01:43 PM
Racing Beat
Old Mar 14, 2006 | 10:15 PM
Drivarotor's Avatar
I just received my RB header, Bonez cat, and Rotary Performance cat back system. as a kit it cost about $900. I wont be able to install it for a month or so, but while I was at it I wanted to match port the intake. Any links and vivid instructions for the throttle body and manifold? What about the 5th and 6th port sleeves? What gives on those? Modify, take out, or replace with upgraded?
Old Mar 15, 2006 | 03:54 PM
run_rabbit_run's Avatar
how about removing your Caps key to save weight?
cristoDathird
28
May 30, 2019 08:47 PM
