Money no object...what would you do?
Old Feb 6, 2002 | 09:02 AM
OmOlsRx7's Avatar
Question Money no object...what would you do?
Assuming you're setting the car up for pure top-end speed, not necessarily off-the-line acceleration, and if money were no object, what would you do? What's the most HP you could squeeze out of a 13B?
I have a '90 GXL in storage that hopefully someday I will do something nasty with. Every once in a while I get nostalgic and browse this board, and today is one of those day.
Sigh.
Old Feb 6, 2002 | 09:24 AM
Ryde _Or_Die's Avatar
Re: Money no object...what would you do?
If your sticking with your NA I would take the engine out and have it fully rebuilt to handle anything and get it ported real good(type of port depends on what you will be using the car for). Then I would get a haltech put in with some larger injectors, better fuel pump & regulator(hey he said money is no object ) That would put you on the safe side for anything. Ok then get a true-dual header & run straight pipes to whatever mufflers(or none). Then I would get myself a supercharger setup from www.atkinsrotary.com . Then I would get myself a small shot of NOS. Oh ya and with pulleys, an electric fan, intake, cold air box, short shifter, lose all the weight I could & put some nice 17" rims(wider in back) with good tires(drag radials for the strip). Get a good clutch with a light-weight flywheel. Personally I would get the gearing changed too. Then I would get the RE Amemiya front end(you all know what I'm talking about) and get the car painted carolina blue. O and can't forget the custom interior Damn I could spend alot of money.
Old Feb 6, 2002 | 09:30 AM
SlithyTove's Avatar
If money were no object.....
I'd buy a McLaren F1.
Old Feb 6, 2002 | 09:31 AM
OmOlsRx7's Avatar
Re: Re: Money no object...what would you do?
Originally posted by Ryde _Or_Die
If your sticking with your NA ...
What about if you turned it into a turbo?
Old Feb 6, 2002 | 09:35 AM
Re: Re: Re: Money no object...what would you do?
I wouldn't turn it into a turbo, I'd go buy a high quality turbo to begin with. I could tell you what I would do but its really long again prolly & not worth it if you would keep your car anyways.
Old Feb 6, 2002 | 09:46 AM
j9fd3s's Avatar
Community Builder
20B
Old Feb 6, 2002 | 09:59 AM
Josepi's Avatar
Despise Enmity
13B Turbo PP. Rebuild engine to stay safe up to 12K. Set idle at 2K. HUUUUGE turbo. N2O for spooling in 1st. Lower gear in diff for top speed.
Old Feb 6, 2002 | 10:41 AM
Samps's Avatar
Racingbeat has already got a second gen to go as fast as it will ever go probably. So if that's what you're after; good luck!
Old Feb 6, 2002 | 10:45 AM
Erik's Avatar
Best of both worlds
yeah, i'd scrap the GXL and get one of those as well
Old Feb 6, 2002 | 10:51 AM
busy13b's Avatar
Om Namah Shivaya
YEP, definately go 20B, big sinle turbo, AEM engine management, upgraded rad, front mount I/C.
Old Feb 6, 2002 | 11:02 AM
rx720bt's Avatar
I'll build an Ultima GTR and stuff it with R26B
or a custom 4 rotor engine.
Old Feb 6, 2002 | 01:17 PM
I think that car is kinda ugly IMO. I would take it and drive it no doubt, but there are much better looking cars, many many better looking ones.
Old Feb 6, 2002 | 06:06 PM
baix2's Avatar
if money is no problem and u only want top speed and still wanna keep the 13B
then throw away everything else and redesign ur body, so it can achieve a high top speed
with a right body design, a 100hp engine car can have a top speed of 200mph +
Old Feb 6, 2002 | 06:36 PM
Mr. ImportGuy's Avatar
Looking for Another RX7
i checked out the specs on that ultima and WOW that thing is a beast 0-60 in 3.3 seconds i want one lol
Old Feb 6, 2002 | 07:12 PM
RX-7Impreza's Avatar
I am the Anti-Ch(rice)t
money no object?????
i wish
build a 6 rotor and fit it in the ultima
justin
Old Feb 6, 2002 | 07:14 PM
Node's Avatar
heavilly ported and carbed N/A
maybe 3.9 or hmmm 3.73 rear end gears, who knows. good luck
Old Feb 6, 2002 | 07:50 PM
RETed's Avatar
JATO!
-Ted
Old Feb 6, 2002 | 08:45 PM
Wicked7's Avatar
20B FD!!!
Old Feb 6, 2002 | 08:47 PM
Node's Avatar
Originally posted by RETed
JATO!
-Ted
BINGO!? now say what? Closest thing I got out of that was JATCO maybe
Old Feb 6, 2002 | 09:18 PM
SlithyTove's Avatar
JATO => Jet Assisted Take Off <something or other>
AF uses em to help the big cargo birds get off the ground on short runways.
Don't you read Darwin Awards? Some AF guy strapped one to his car in the middle of a desert. He hit 400 mph before he was able to react (too many Gs) at which point he hit the brakes which pretty much stripped off his tires, axles, etc. Shortly thereafter he went airborne and rammed into a cliff about half a mile up. Only real evidence of the guy they found were the teeth they dug out of the steering column.
Hella fast, but a one way trip.
Old Feb 6, 2002 | 09:31 PM
Beast From The East's Avatar
Racing is Life.....
Titan 4
As earlier stated, if top end is all you're considering.....
Modify a Titan 4 launch vehicle to accept your FD on the front.
The first 17,000 mph FD ....... that gets 1ft/50 gallons on fuel consumption.
Yeeeeehaaaawwwww!
Screw nitrous ... give me liquid O2 propellant instead :-)
Old Feb 6, 2002 | 09:32 PM
E6KT2's Avatar
But the Ultima is not about how it looks (like A**, we know), it's about how it goes!
Old Feb 6, 2002 | 09:45 PM
easy p-cheesy's Avatar
SPORKY
Originally posted by j9fd3s
20B
thats it? I'd probably try to get a charter bus and have a custom 20 rotor made.
Old Feb 6, 2002 | 11:07 PM
i thought it was an old sidewinder missle???
Justin
Old Feb 6, 2002 | 11:11 PM
ok the ultima looks strangely like a porsche that i saw on speedvision.
is this a porsche body????
Justin
